Where's Your License Plate?
akcucv
Phoenix, AZ
So I haven't been pulled over yet but I have had my plate just taped to the back window. Now i want to put it some where else that is permanant. Here they will pull you over for not license plate light so i have to wire a light. But my question is where has everybody else mounted their plates. I would like to see pictures to get an idea. I think my best idea was to get a mount for the hitch, but what if i tow a trailer then i have to figure out a different place. So let me see what you guys have done.
hobie237
Newark, DE
I've got two self-tapping screws holding mine onto the tailgate. A little 12v trailer light on the side of the bed lights it up when the lights are on (wired into taillight).
K45
Statesville NC
I thought about this as well. i do nto know about yall but I would not be using my pinticle hich much, so I thought about puting it there and leave off the pintcle all togethor or have a flip up design like they did with oldr car that had the gas cap behind the plate. Then whenever you are using the pinticle you bolt it up and the plate is fliped up because no one is going to see it from behind anyways. Thats the only clean way without drilling a bunch of holes in a tailgate. Good luck
dunedigger
Hart, MI
I gave up on the bumper on my M1009. I used screws into the tailgate. I didn't mind cuz there is quite a dent in it and I'm thinking about replacing it. I don't like it on the tailgate so I'm not sure what I will do yet. I saw a picture of someone on here that fabed up something that hooked over the bumper, that is likely what I will do.
Croatan_Kid
New Bern, NC
Right side of the rear bumper, over the blackout light and I have a license plate light for a trailer on a small stainless steel bracket bolted on above it. I tapped the light's power wire into the tail light wire. It's looks like it would be in the way, but I've never hit it with anything and it clears when the tailgate is down. I'll look for a picture for reference.
EDIT: you can't really see the license plate light in this pic, but it's the best one I found.
BobM
Fillmore, Indiana
I too removed the pintle hitch and put the plate there. I am planning on adding a reciever hitch under the bumper and making a pintle to fit. No light, yet.;-)
EO2NMCB
23
DeSoto, MO
On the 1009 there is a large hole 3/4" maybe on the the bottom of the bumper, one on each side. Used some stainlees to make a bracket, bolted to the bottom bumper left side. No drilling required.
K45
Statesville NC
All those that are placing it in the area where the pinticle is, can you use a civilian wiring harness at the bumper and the light set up and just unplug the harness at the turn signals and put the other one in? Will this work? If not I guess just running wire and a light and tie into the headlight switch could work I guess.
mkcoen
381
Spring Branch, TX
"no plate" is an option in TX. Use bumper #'s on the front.
Unfortunately in TX the "no plate" option is not widely known among the LEOs. I've been pulled over twice and even though I have a copy of the statute in my glovebox the only thing that saved me from a ticket was also having a trip permit. Yeh, I could have gone to court and probably got it tossed but it's not worth the effort. I've finally gotten sick of it and will just be adding the plate to avoid all the hassle.
sixfeathers
Banned
68
Baltimore/Maryland
Here is mine. Don't have light yet. But its in a spot so that anyone behind you can see it with ease. I used my charger head lights as a marker then drilled two holes ,burn up a drill bit, then placed the nuts and bolts on.. As far as lights youthink that since it has Historic tags on it they would give us a break.. Well I guess We will see.
