ETN550
- 9
- 0
- Knoxville, TN
Agree. If the pump does not work with 24vdc applied first take the end cap off and make sure the plunger can move freely. If it does move freely reassemble and cut out the RF supressor and wire it direct and try again. 50% of the main pumps I see on the 016E are bad and 50% of those bad ones will run with the RF supressor cut out of the wiring.If you get 24V at the pump and the pump isn't moving fuel then the pump is bad. You may be able to switch the main and aux pumps and get it to work. If no 24V at the pump then maybe something else is wrong.
If it ran for a while and then stopped you may have to bleed the fuel system once you get the electric pump working.
IIRC there is a nice little Facet pump that costs less and works well. ebay and Aircraft Spruce are sometimes good places to find 24V DC fuel pumps.
Not that we can do anything about this but it seems as though the newer round pumps like those supplied in the conversions operate slightly differently then the old round style. I have noticed the old style only move back and forth when fuel flows. This action can be heard on the countless videos of people priming and running the engines. they click rapidly until fuel pressure builds then they click slowly. The newer style tends to oscilate rapidly but with tiny strokes whether fuel is moved or not. And another possible issue is the Yanmar fuel system is dead headed. That is there is no return line from the injection pump to allow constant fuel circulation. I think the pumps live best when they can circulate some fuel to stay cool and allow the plunger to stroke more like on the MEP 002 and 003 systems. I have been tempted to make a bypass line with an orfice from the line to the injection pump to the return line to the tank. The injection pump itself only needs gravity feed.
If anyone experiences multiple pump failures on the 016E I recommend they try making the bypass line. I'm pretty confident the pumps would live longer if they constantly circulated fuel. I would prefer finding a running used old take out pump over new one at this point. Fortunately, the aux pump is usually old and can swap in place of the main pump that has failed. Then put the new replacement in the aux position where it might live.
