Who has ordered from LMC
caladin
So Cal
Once I complete the painting and rust cleaning of the cab I plan to replace all of my rubber. LMC has it very nicely spread out in the catalog but CK5 forum guys seems to have a 50-50 chance of getting good vs crap from them. Here is what Im looking to replace. Any recomendations?
Cab seal Kit w/Black Trim $150 <38-6256>
Lower Side Seal - LH $40 <38-6192>
Lower Side Seal - RH $40 <38-6193>
Rear Glass Rubber-Upper $70 36-6199
Tail Gate Seal-Lower $25 38-6963
Window Seal Kit $60 <38-5655>
Window Channel Kit $99 <38-5651>
Vent Glass Seal - LH <38-6074> $20
Vent Glass Seal - RH <38-6075> $20
Aluminum Door Sill Plate Set <38-2402> $30
ranchhopper
139
south elgin illinois
LMC has high shipping rates they go by how much you spend to calculate shipping I usually go to brothers or grumpys truck parts instead. I never had a problem with LMCs products just their shipping rates but they might have changed their shipping policy since I bought from them years ago.
johnsr
lafayette in
i have ordered from lmc. i have got the front leafsping bushing and hanger kit for a 88 k1500 suburban, the shifter boots for a 85 k10 pick up(4 speed with a np205 tcase) and other odds and ends. evry thing has fit/worked great. as for the rubber seal for your doors and windos, be carfull i have had some problems with them fitting right(never got them from lmc though).
Gottlos
Former 95B Ft Sam Houston
Canyon Country, CA.
I ordered my door panels, side marker and tail lights, rear view mirror, side mirrors and an underhood light from them. The shipping is high but everything was packaged well. I haven't found anything to complain about. Yet.:beer:
lnnayers
bethany oklahoma
i have ordered from them with good results as well. if you are going to order the vent rubbers, be sure to get the replacement rivets for the upper pivot.
1redgmc
9
West Virginia
I've rebuilt two trucks with LMC parts. I've purchased an equal amount from other vendors. I agree - shipping is high with LMC - so it pays to consolidate the order if you have the ability to do so.
Stating what has been said before - quality varies. Some of the reproduction parts are junk, while others are equal to OEM quality.
I've found that SOME of the rubber pieces I've purchased do NOT have the UV resistance of locally purchased / OEM items. They deteriorate rapidly, and do not hold up well at all. In particular - windshield and rear window rubber did not last. Window channel and vent rubber? No problem.
I'm not trying to steer you away from LMC - as I've been satisfied overall and only had trouble with the few pieces I've mentioned.
Good luck!
121
Metairie, LA
I used Classic chevy truck parts of America. I have also used LMC. Overall, Most all of the items I have purchased from Classic Chevy were of better quality. Particularly the seals and weatherstrip.
91W350
57
Salina, Kansas
I had good luck with them, if I shopped around, I could generally buy cheaper and get cheaper shipping. Their products always seemed good, they never sent me anything that got damaged by shipping and they were fast. I would go back if I needed something. Glen
Atwater
barker, new york
vent window rubber was one of the things i got from lmc. wish i had not bothered as the new seals dont fit or well seal nearly as well as the originals:x.
the hood i got seems ok, the door i ended up not using, wish i had just spent more time finding a good original.
overall i personally prefer, when possible, to go elsewhere
NPD732
Chesapeake VA
Most of the seals are still available from Chevy. Get the part numbers from the TMs and order from your favorite online discounter. They may cost a little more, but they will outlast any of the aftermarket seals.
