- 1,046
- 45
- 48
- Syracuse, New York
mine is almost the same as his, 20psi on the gov limiter and water injection. never over 1200degrees.Pulling a load I maintain 25 psi of boost. My truck has a Intercooler installed and it makes a huge difference. I never let the egts go over 1200.
Is this a M35A2 you're talking about? If so,Pulling a load I maintain 25 psi of boost. My truck has a Intercooler installed and it makes a huge difference. I never let the egts go over 1200.
I'm just curious how you shoehorned a intercooler in there.
Yes, I've seen that thread. I've still never seen one added on a M35A2.Check this out, http://www.steelsoldiers.com/5-ton-up/43109-m52a2-aia-air-intercooler.html
I wish I could take credit, b/c he did a great job on it, with all the other mods I have done I get a 300 degreze differintal between the air going into and coming out. Very Impressive. By the way I cant Spell. LOL
I'm not trying to turn Mah Deuce into a dragster, but I've got a fresh LDS sitting in a crate and was planning on re-torquing the rod-ends and mains anyway before I install it. Not knowing the history of a rebuilt engine like this (or any of the engines in our trucks), my question is - why NOT replace the rod-bolts if you're in there anyway and parts are available and reasonably priced?I think that if you solve the engine's tendency to throw rods, you will start to see its tendency to stretch caps. And if you solve its tendency to stretch caps, you will start to see its tendency to bust cranks. And if you solve its tendency to bust cranks, you will start to see its tendency to burn holes in the pistons... It is close to its practical limits. There isn't going to be a revelation that saves the day... not at such high speeds on such a long stroke engine with such a high compression ratio and such a heavy piston.
I sent an email to ARP to see if they had any or could make them. Might be cheap insurance...
Let me know if you need any help with this. I don't want to cut-in, but I've worked with ARP in the past and have contacts there that might be able to tell us what we want to know. If they have any parts on the shelf that will work for us, seems like a no-brainer to me. Cheap insurance. If they'd have to make custom bolts, then I'd want to know more about whether this is really a problem that needs to be solved before going any further.ARP rod bolts range in price from $50-150 a set. The oil pan gasket is ~$25. So it might work out to be less than $200 for a bolt upgrade. I've been researching all the rod failures and I've only seen the cap separating from the rod. It probably would be worthwhile to upgrade the main bolts as well while you're in there. Again, if someone had this hardware laying around, I'll see what I can come up with.
Nope!http://www.steelsoldiers.com/deuce-modification-hot-rodding/6731-pulling-tractor-deuce-engine.html
I was searching and ran across this older thread. 4000 rpm at the starting line and 500hp...
Does anyone know what the injection timing is? I thought I read somewhere that it was 20 deg BTC. Could this be putting a huge load on the rods and everything?
Too much advanced timing in a gas engine can lead to pitted pistons, sheared cranks...
Go to the first post in this thread: http://www.steelsoldiers.com/deuce/44121-55mph-detonation-11.htmlDoes anyone have close up pics of failed rods? That may help.
They don't actually.... My Detroit 6-71N red lines at 2100, but because every downward stroke of the piston is a power stroke (as opposed to every other stroke on a 4-cycle engine) my Detroit SOUNDS like it's doing 4200!What I would like to know is why the 2-strokes can rev so high?
