I have to revive my post of 9/20/11 as yesterday I drove from Portland to Eugene and got a no start situation. I had to be towed home $500!
I have a 28MT starter that has been running fine on my daily driver M1009. I had already done the Doghead mod long ago. I carry a spare relay so I changed that in first. Also checked my GP card's contacts- looked great. I pulled the starter and applied juice with a jumper cable from both 12volts and 24 volts it spun but did not advance the starting gear into where the Flexplate gear would be. Installed on the Blazer I didn't even get that... only the sound of the solenoids.
I reread my previous postings just now and had questions about what some members believe the problem to be. My original post and two responses follow:
Why do these (mine anyway) go through starters? Is there supposed to be more regulation to the starter? From what jersey4x4 stated: "What happens is the button in the solenoid gets burnt or corroded(Both happened) and you get the click and no power across the large terminals of the starter to power the armature."
The juice carbons build up to prevent the strap from the solenoid to deliver a charge to the starter proper. How can this keep happening and yet no one here seems to address it as a known problem? Is this not what the problem IS?
4 starters in two years as many relay for the doghead mod, and tow bills. I have got to:
figure out the problem and eliminate it OR
switch to 12 volts ( I hate this) so I can control the firing of the starter>
Please help- my wife wants me to sell all my trucks and get a Challenger
Code:
under the dash. I have replaced my batteries with two new ones. The GP card is new from Antenna Climber.
I have been driving it for months since I cleaned the GP card contacts with sandpaper and inserted the new GP card. But today, out-of-the-blue, I turned the key, the WAIT light came on for 6-7 seconds as usual. I turned the key and get gauge lights and a soft snap (the gp relay?) then the loud snap of the starter relay behind the dash. I found that if I hold the key in the START position a millisecond too long that I also get this kind of Ned Beatty squeal?
Just removed all the battery cables and cleaned them. The Batts tested at 12.55 each, so I expect that this is enough juice to crank the starter. Pulled the red wire from the rear battery to the junction block near the GP relay. It has a good connection. The pink and green leads on the IP also got a scrub down.
The Doghead relay was swapped-in 6 months ago and seemed fine all this time with the exception of an occasional no crank, followed by a crank and start immediately after. I see this condition asked about frequently on this forum; but have yet to see a definitive cause listed. Since the ignition circuit seems to be the only circuit involved, why is the culprit so illusive? I have replaced batteries, GP card, starter relays, and invested a lot of time in this same problem last time it happened. It mysteriously disappeared after installing the new GP card last time; but I don't think that was the true problem.
Has anyone here truly narrowed the problem down to a failed component, or cause ever?
Code:
JERSEY 4X4: I had a starter die on my(Delco) after almost 10 years and went the cheap route of one of those eBay 28mt clones and now am on the third one in about 5 months. What happens is the button in the solenoid gets burnt or corroded(Both happened) and you get the click and no power across the large terminals of the starter to power the armature. I just got my brand new Delco starter today and it will be on tomorrow and mine will never do that again. Easy to test with volt meter or just a jumper wire with a light bulb on the armature side of the starter solenoid.
Code:
acesneights1:It is unlikely that the wire is broken in the harness. Not saying it can't be but usualy they break, deteriorate in exposed places. If you have power at the starter sol, the starter is toast, If you have no power at the starter sol then go back to the doghead relay and test there. Obviously since you did the mod, you understand the wiring, I hope...:beer:
If you have no power there on the 12v key side, probably the ign switch. If no power on the 24v constant then you need to trace that back. If you have power everywhere on the sol it's supposed to be then it's in the harness or connector...
