Will This Fuel Injector Fit???
Florida9
Lantana, FL
Can any of you tell me if this fuel injector will fit in my 85 chevy m1008 6.2l its from a 87 CHEVY SUBURBAN 6.2l the guy wants $225 for it
southdave
ripley, oh/TDY Lordstown,Oh
Here is a veeerrryy long list of manufacturer codes for the DB2 pump, good luck finding the right one!
GM 6.2L & 6.5L APPLICATIONS AND SUPERSESSION
INFORMATION
DATE: April 27, 2001 SUPERSEDES: P.B. 119R5 dated 5/21/97
DB2829-4127 14050526 1982 LD Truck - ALT. C/K — —
DB2829-4151 14061645 1983 P Truck (Motor Home) C/K — —
DB2829-4153 14050588 1982-83 HD C/K & P Truck C/K — —
DB2829-4187 14066280 1983 LD & HD C/K Truck - ALT. C/K — —
DB2829-4188 14066277 1983 LD G Van G — —
DB2829-4189 14066278 1983 HD G Van G — —
DB2829-4190 14066279 1983 LD & HD G Van - ALT. G — —
DB2829-4266 14077133 1984 P Truck (Motor Home) C/K — —
DB2829-4267 14077179 1984-85 CUCV (Military), HD C/K, D Truck C/K DB2829-4520 Note 2 except (d)
DB2829-4268 14077135 1984 HD G Van G — —
DB2829-4269 14077136 1984 HD C/K Truck - ALT. C/K — —
DB2829-4270 14077137 1984 HD G Van - ALT. G — —
DB2829-4274 14077168 1984 LD C/K Truck C/K DB2829-4425 Note 3
DB2829-4275 14077171 1984 LD C/K Truck - ALT. C/K DB2829-4426 Note 3
DB2829-4276 14077169 1984 LD G Van G DB2829-4427 Note 3
DB2829-4277 14077170 1984 LD G Van - ALT. G DB2829-4428 Note 3
DB2829-4305 14077134 1984 CUCV (Military), HD C/K, D Truck C/K DB2829-4267 Note 4
DB2829-4309 14077185 1984 LD C/K Truck - CAL. C/K — —
DB2829-4310 14077186 1984 LD G Van - CAL. (Man. Trans.) G — —
DB2829-4355 23500014 1984 HMMWV (Military) C/K DB2829-4471 Note 5
DB2829-4366 23500077 1984 LD G Van - CAL. (Auto. Trans.) G DB2829-4439 Note 5
DB2829-4386 23500256 1984-85 CUCV (Military), HD C/K, D Truck - 1.2 cSt C/K DB2829-4521 Note 2
DB2829-4410 23500251 1985 HD C/K & P Truck C/K DB2829-4544 Note 2
DB2829-4411 23500252 1985 HD G Van G DB2829-4509 Note 2
DB2829-4412 23500253 1985 HD C/K Truck - ALT. C/K DB2829-4510 Note 2
DB2829-4413 23500254 1985 HD G Van - ALT. G DB2829-4511 Note 2
DB2829-4425 14077168 1985 LD C/K Truck C/K DB2829-4502 Note 2 except (d)
DB2829-4426 14077171 1985 LD C/K Truck - ALT. C/K DB2829-4506 Note 2 except (d)
DB2829-4427 14077169 1985 LD G Van G DB2829-4503 Note 2 except (d)
DB2829-4428 14077170 1985 LD G Van - ALT. G DB2829-4507 Note 2 except (d)
DB2829-4437 23500273 1985 LD C/K Truck - CAL. C/K — —
DB2829-4439 23500275 1985 LD G Van - CAL. (Auto. & Man. Trans.) G — —
DB2829-4440 23500276 1985 HMMWV (Military) - 1.2 cSt C/K DB2829-4523 Note 2
DB2829-4441 23500277 1985 HD C/K & P Truck - 1.2 cSt C/K DB2829-4512 Note 2
DB2829-4471 23500398 1985 HMMWV (Military) C/K DB2829-4524 Note 2
DB2829-4502 23500400 1986-87 LD C/K Truck C/K — —
DB2829-4503 23500401 1986-87 LD G Van G — —
- 2 - P.B. 119R6
†† At the time of supersession parts and/or calibration changed as noted. Other changes may have occurred since.
Engine Systems
C/K — Injector - 84 mm length, 6 mm dia. nozzle valve; Lines - 2.50 mm I.D.; Delivery Valve Retraction - 30mm3
G — Injector - 74 mm length, 5 mm dia. nozzle valve; Lines - 2.00 mm I.D.; Delivery Valve Retraction - 22.5mm3
* — Injector - 74 mm length, 5 mm dia. nozzle valve; Lines - 2.36 mm I.D.; Delivery Valve Retraction - 22.5mm3
Notes
1 — Timing (Ref. S.B. 375)
2 — (a) Transfer Pump Filter; (b) Advance Piston (S.B. 393R3);
(c) Delivery Valve Stop & Spring (S.L. 250R2); (d) Governor Spring
3 — (a) Min-Max Governor Pushrod; (b) Non-grooved Metering Valve (S.B. 336R4)
4 — Housing; Drive Shaft Retention (S.B. 419)
5 — Min-Max Governor Pushrod
Model GM P/N Year Application
Engine
System Superseded by Changes††
DB2829-4506 23500404 1986-87 LD C/K Truck - ALT. C/K — —
DB2829-4507 23500405 1986-87 LD G Van - ALT. G — —
DB2829-4509 23500407 1986-87 HD G Van G DB2829-4646 Note 6
DB2829-4510 23500408 1986-87 HD C/K & P Truck - ALT. C/K — —
DB2829-4511 23500409 1986-87 HD G Van - ALT. G DB2829-4648 Note 6 exc. (b)
DB2829-4512 23500410 1986-87 HD C/K & P Truck - ALT. C/K — —
DB2829-4520 23500413 1986-87 CUCV (Military), HD D Truck C/K — —
DB2829-4521 23500414 1986-87 CUCV (Military), HD D Truck - 1.2 cSt C/K — —
DB2829-4523 23500415 1986-89 HMMWV (Military) - 1.2 cSt C/K — —
DB2829-4524 23500416 1986-89 HMMWV (Military) C/K — —
DB2829-4544 23500346 1986-88 HD C/K & P Truck C/K — —
DB2829-4548 23500587 1986-88 Industrial - 12V (Clark) C/K — —
DB2829-4554 23500931 1988-89 LD C/K Truck (Auto. Trans.) C/K — —
DB2829-4555 23500933 1988-89 LD C/K, R/V Truck - ALT. (Auto. Trans.) C/K — —
DB2829-4574 23501280 1987-88 Generator - 24V (Clark), 1800 RPM C/K Made from
DB2829-4548
DB2829-4581 23500932 1988-89 LD C/K Truck (Man. Trans.) C/K — —
DB2829-4582 23500934 1988-89 LD C/K Truck - ALT. (Man. Trans.) C/K — —
DB2829-4612 23501993 1987-88 Industrial - 24V (Clark), 3600 RPM C/K Made from
DB2829-4548
DB2829-4636 23500941 1988-89 LD G Van (Auto. Trans.) G — —
DB2829-4637 23500942 1988-89 LD G Van (Man. Trans.) G — —
DB2829-4638 23500943 1988-89 LD G Van - ALT. (Auto. Trans.) G — —
DB2829-4639 23500944 1988-89 LD G Van - ALT. (Man. Trans.) G — —
DB2829-4646 23502177 1988 HD C/K, R/V, P Truck & G Van G DB2829-4723 Note 7
DB2829-4647 23502178 1988 HD C/K, R/V, P Truck & G Van - 1.2 cSt G DB2829-4724 Note 7
DB2829-4648 23502179 1988 HD C/K, R/V, P Truck & G Van - ALT. G DB2829-4725 Note 7
DB2829-4655 23502229 1988-89 Industrial - 12V (Clark), 3600 RPM, 1.2 cSt C/K Made from
DB2829-4548
DB2829-4701 23503123 1988-89 LD R/V (Auto. Trans.) C/K — —
DB2829-4723 23503998 1989 HD C/K, R/V, P Truck & G Van G — —
DB2829-4724 23503999 1989 HD C/K, R/V, P Truck & G Van - 1.2 cSt G — —
DB2829-4725 23504000 1989 HD C/K, R/V, P Truck & G Van - ALT. G — —
DB2829-4779 10149610 1990 HD C/K, R/V, P Truck & G Van G — —
DB2829-4780 10149619 1990 HD C/K, R/V, P Truck & G Van - 1.2 cSt G — —
DB2829-4781 10149620 1990 HD C/K, R/V, P Truck & G Van - ALT. G DB2829-4877 Note 8
DB2829-4790 10149609 1990 LD C/K, R/V & G Van (Auto. Trans.) G — —
DB2829-4791 10149621 1990 LD R/V Truck & G Van (Auto. Trans.) - ALT. G — —
DB2829-4792 10149611 1990 LD C/K Truck (Man. Trans.) G — —
DB2829-4793 10149618 1990 LD C/K Truck (Man. Trans.) - ALT. G — —
DB2829-4801 10149623 1990 Industrial - 12V, 3600 RPM G — —
DB2829-4802 10149646 1990 Generator - 24V, 1800 RPM G Made from
DB2829-4801
- 3 - P.B. 119R6
GM Injection Pump Application and Supersession Guide
6.2 Liter Applications
Engine Systems
Notes
6 — (a) Calibration; (b) Air Timing; Drive shaft Retention (Ref. S.B. 419)
7 — (a) Min-Max Governor Spring; (b) Transfer Pump Regulator Spring; (c) Advance Spring; (d) Calibration
8 — (a) Advance Piston; (b) Spring Side Advance Plug; (c) Advance Spring; (d) Calibration; (e) T.P. Regulator
(f) Housing Pressure Regulator/Return Connector
Engine
DB2829-4803 10149647 1990 Industrial - 24V, 3600 RPM G Made from
DB2829-4801
DB2829-4804 10149648 1990 Industrial - 12V, 1.2 cSt G Made From
DB2829-4801
DB2829-4833 10149622 1990 Marine (Peninsular Diesel) G — —
DB2829-4840 10149679 1990 LD C/K Truck (Auto. Trans.) - ALT. C/K — —
DB2829-4847 10149679 1990 HMMWV (Military) G DB2829-4878 Note 8 exc. (e) & (f)
DB2829-4848 10149634 1990 HMMWV (Military) - 1.2 cSt G DB2829-4879 Note 8 exc. (e) & (f)
DB2829-4875 10149610 1991 HD C/K, R/V, P Truck & G Van * — —
DB2829-4876 10149619 1991 HD C/K, R/V, P Truck & G Van - 1.2 cSt * — —
DB2829-4877 10149620 1991-92 HD C/K, R/V, P Truck & G Van - ALT. * — —
DB2829-4878 10149633 1990½ HMMWV (Military) G — —
DB2829-4879 10149634 1990½ HMMWV (Military) - 1.2 cSt G — —
DB2829-4894 10183929 1991 LD C/K, R/V & G Van * — Notes 9 & 11
DB2829-4895 10183930 1991 LD C/K, R/V & G Van - ALT. * — —
DB2829-4959 10191495 1990 Marine - 3600RPM * — —
DB2829-4974 14098680 1991 Marine (Peninsular Diesel) - Turbo (250 hp) * — —
DB2829-4977 10154613 1992 LD C/K, R/V & G Van * DB2829-4894 Note 10
DB2829-4978 10154614 1992 LD C/K, R/V & G Van - ALT. * DB2829-4895 Note 10
DB2829-4979 10154615 1992 HD C/K, R/V, P & G Van * DB2829-4875 Note 10
DB2829-4980 10154616 1992 HD C/K, R/V, P & G Van - 1.2 cSt * DB2829-4876 Note 10
DB2829-4981 10154617 1992 HD C/K, R/V, P & G Van - ALT. * DB2829-4877 Note 10
DB2829-5048 10154678 1992 P Truck - 2500 RPM (120 hp) * — Note 10
DB2829-5050 10154699 1992 P Truck - 2600 RPM (135 hp) * — Note 10
DB2829-5055 10154685 1993 LD C/K, R/V, & G Van - ALT. * — Notes 10 & 11
DB2829-5056 10154684 1993 LD C/K, R/V, & G Van * — Notes 10 & 11
All speeds are in engine rpm unless otherwise noted.
1. Injection pump operating speed is half of engine speed.
2. Injection pump rotation is counterclockwise.
3. Injection pump is timed to the outlet port in the 10 o’clock position when viewed from the transfer pump end.
The oem 6.2 pumps are 0.290 dia plungers - the oem 6.5 pumps are 0.310 plungers, marine-service pumps are available with larger plungers
PRE-1990 (6.2L) FUEL INJECTION PUMP (DB2829-4523) CALIBRATION Military
- 4 - P.B. 119R6
Engine Systems
Notes
8 — (a) Advance Piston; (B) Spring Side Advance Plug; (c ) Advance Spring; (d) Calibration; (e) T.P. Regulator
9 — 1991 LD C/K, R/V, and G Van do not require S.O. I. Sensor
10 — Start of injection (S.O.I.) Sensor, P/N 26605, beginning with 1992 MY (S.B. 469)
11 — (a) High Force HPCA Solenoid; (b) Housing Pressure Regulator/Return Connector; (c) Calibration
12 — (a) Unpotted Encoder Sensor; (b) Ceramic Rollers
Engine
DB2831-4911 10183901 1992-93 HD C/K & P - Turbo (200 hp) * — Note 10
DB2831-4927 14098655 1992-93 HD C/K & P - Turbo, 1.2 cSt * — Note 10
DB2831-4970 10154607 1992-93 SD - Turbo (15,000 GVW) * — Note 10
DB2831-4971 10154608 1992-93 SD - Turbo (15,000 GVW), 1.2 cSt * — Note 10
DS4831-5067 10225930 1994-96 LD & HD C/K, G, and P3 Truck & Van * DS4831-5288 Note 12
DS4831-5068 10225929 1994 HD C/K, G, and P3 Truck & Van * — —
DB2831-5079 10224039 1993-97 2½ Ton Cab-over (Military) - Turbo (200 hp) * — Note 10
DB2831-5088 10229115 1994-97 HD P & G Van - N/A (170 hp) * — Note 10
DB2831-5089 10229119 1994-97 HD P & G Van - N/A, ALT. * — Note 10
DB2831-5119 10238967 1994-97 HD P Truck - N/A, 2600 RPM (120 hp) * — Note 10
6.5 Liter Applications
- 5 - P.B. 119R6
Engine
DB2831-5129 12550269 1994 HD P & G Van - N/A, 1.2 cSt (170 hp) * — Note 10
DB2831-5149 12550433 1994-96 HMMWV (Military) - N/A, 1.2 cSt (170 hp) * — —
DB2831-5157 12551521 1994 HD O.E.M. - Turbo (200 hp) * — Note 10
DB2831-5164 12552397 1992-93 HD C/K & P - Turbo (Man. Trans.) Service * — Note 10
DB2831-5167 12552621 1992-93 SD - Turbo (15,000 GVW) Service * — Note 10
DB2831-5209 12555697 1995-97 HD (Military) - N/A, 1.2 cSt * — —
DS4831-5288 12558156 1997-98 LD & HD C/K, G, and P3 Truck & Van * DS4831-5459 Note 13
DB2831-5323 12559097 1997 HD 6.5 replacement for 6.2
(3 speed Auto. Trans.)
* — Note 10
DB2831-5436 12561383 1994 HD P& G - (170 hp) * — Note 10
DB2831-5437 12561384 1994 HD P& G - ALT. * — Note 10
DB2831-5438 12561385 1994 HD P - 1.2 cSt, 2600 RPM (120 hp) * — Note 10
DS4831-5459 12561405 1999 LD & HD C/K, G, and P3 Truck & Van * DS4831-5521 Note 14
DB2831-5485 12561514 1998-00 HD (Military) - Turbo, 1.2 cSt (200 hp) * — —
DS4831-5521 12561307 2000 LD & HD C/K, G, and P3 Truck & Van * — —
Engine Systems
Notes
13 — (a) Inner Bearing Retainer/Thrust Washer; (b) Encoder Sensor; (c) T.P. Blade Spring; (d) Calibration
14 — (a) Stepper Motor and Stop; (b) Pump Mounted Driver
Arctic pumps:
DB2829-4655 23502229 1988-89 Industrial - 12V (Clark), 3600 RPM, 1.2 cSt C/K Made from DB2829-4548
DB2829-4804 10149648 1990 Industrial - 12V, 1.2 cSt G Made From DB2829-4801
10
Stanadyne lists the following IPs as military without a civilian application: 4355, 4440, 4471, 4520, 4521, 4523, 4524, 4847, 4848, 4878, 4879 for 6.2s and some other 5XXX IPs for military 6.5s.
DB2829 - 4875 not listed as military but military suplus shows they were purchased for $1800 each.
Known fuel delivery specs.
PARTS BULLETIN
NO: 119R6
Engine
DB2829-4090 14050587 1982 LD C/K Truck C/K DB2829-4126 Note 1
DB2829-4091 14050588 1982 HD C/K Truck C/K DB2829-4153 Note 1
DB2829-4126 14050587 1982-83 LD C/K Truck C/K — —
__________________
Cucvnut
75
Carver, Oregon
the list says no. but im not a professional. you need a
Florida9
Lantana, FL
Do you know what the site is? the only problem i have is that the piece broke off where the Vacuum Valve goes on but besides that the pump works i just cant get it to shift out of first without it
Florida9
Lantana, FL
On the driver side of the fuel injector pump is the throttle that throttle is hooked up to a rod that goes threw the injector pump to the passenger side where is hooks up to the Vacuum regulator valve that rod is broken that goes threw the pump
epitts
-1
Terre Haute, Indiana
I also think it will work, but for Sh-ts and grins try hooking your vaccum pump direct to the trans and see if it works. It is my understanding the valve only adjusts shift firmness. YMMV
Hasbeen
Ellis County Texas
I need to ask a dumb question since I don`t know cuccv`s.
Are they 12volt or 24 volt systems?
I`ve been under the impression that they were 24v.
If they are 24 volt the fuel shut off solenoid in the top cover of the pump will need to be donated from your old pump into the replacement 12v pump.
That`s only a 5 minute nut driver job if required.
I used to know a little bit about those pumps, but I`ll apologize for my ignorance on the cuccv electrical.
Good Luck!
Hasbeen
DIESELGREEN
Woodstock, GA
I saw that pump on e*ay too, along with all the other stuff from his truck. I will assume you got a link from that vendor in florida, if so I would opt for the correct HD pump, not the civvy version.
