Winch Plate decals/labels??
maddawg308
762
Appomattox, VA
I believe Rod Shaver at MVDataplates.com is the man to speak to about replacements, although I believe he is out of them right now.
emmado22
148
Mid Hudson Valley NY
one says
CAUTION PULL OUT DRUM LOCK BEFORE OPERATING WINCH
One is the winch serial # dataplate, with the manufacturers name, ect
one says WARNING DO NOT FORCE CLUTCH LEVER TO FREE DRUM CLUTCH, ENGAGE POWER TAKE OFF IN FORWARD OR REVERSE GEAR AS REQUIRED, AND SLIP ENGINE CLUTCH SLIGHTLY
1,808
DOT 3 brake fluid will do that too given enough time and applications. I use it on DATA plates all the time.
2,758
Saturn gas them all. The center one will be blank when you get it. I think they are around 5 bucks or so each.
