1987cucv
- 19
- 3
- North Dakota
Hi folks,
I just put in a new radiator (thanks to WWRD99 for help finding the right fittings!) and the truck died on me while bleeding the coolant system. Now it wont restart, and the starter sounds sad.
Here is a video of it trying to start:
Here's what happened:
Here's what I've checked:
I've read through the TM, but I'm at a loss. The section for "SLOW CRANKING OR UNUSUAL NOISE DURING CRANKING" is basically just checking the starter - which seems fine from what I can tell.
What should I be looking into here? Thanks fellas
- Installed new radiator, added flued, and started truck to bleed the system
- With the truck running, noticed a leak from the lower oil cooler line -turned off truck and fixed the leak.
- Didn't lose much oil, but checked the level and added about the same amount that was lost
- Started the truck, ran it for a while and monitored for leaks.
- Turned off the truck for a lunch break
- Came back, started the truck, and it fired up, but then died about the time I got out to the radiator
- Noticed smoke coming from the rear of the engine
- When restarting, it wouldn't fire and now the starter sounds weak.
- Checked the battery wiring, seems correct:
- Checked battery voltage, 12.65v on both batteries
- Checked the glow plugs, they start at 9v and climb to 14.6v
- Investigated the smoke at the rear of the engine, its happened before but whenever it has its gone away quickly (just like this time. Thoughts on the cause:
- Dust burning off of whatever this thing is:
- Duct tape on this diode (thanks snuffy )
- Fusable link burning up
- Oil from my leaking passenger side valve cover (its on my list to fix! s) burning up on the starter?
