- 1,648
- 814
- 113
- Central NY
Whilst reinstalling the straightened bumper, I decided to adjust the position of the vise, on it's plate as one of the holes had been drilled through the edge of the bumper!
It's an Anchor vise, 3 mounting lugs vs the 4 lugs of the original (??) Wilton.
Looks like one of the upgrade hole was hastily burnt through.. that will be filled. This is the under side of the plate.
Clamped with 1" Aluminium backing block. This will sinc heat away from the initial weld pool but surprisingly doesn't melt.
This is a 4" (jaw size) Wilton "Bullet" that I picked up - base needs repairing, just for info - the M816/M543/M936 uses a 5" vise.
The Wiltons mounting lug patern is not a square, again, this pic is jusr for reference, from the 4".
4 original Wilton holes, inservice replacement Anchor holes (one shared), note foreward hole drilled (burnt?) through bumper (can just see edge of repaired bumper through hole) and 3 new holes for it's adjusted position.
Anchor #5 vise in approximate new position.
My 816 came with an Anchor vise, but the the bumper mounting plate had other holes.. It appears that the Anchor vise was an inservice change from a Wilton. The Wilton, has 4 mounting lugs, whereas, the Anchor, only 3.
Note one of the holes for the 'upgrade/replacement' Anchor vise had been drilled through the bumper, the edge of the top flange, weakening it. So, I repositioned it, 3 new holes, and will fill the upgrade holes, but keeping the Wilton holes.
