Coriolis2K
- 0
- 0
- Hartford, Wisconsin
OK, I used the search function and did not find exactly what I was looking for...found some good info none the less. I am not sure if what I found pertains to my particular situation.
I left it sitting at a friends place for a few months while I was out of town, backed it into a parking space and there it sat for 3 months until today.
Started right up and dropped it into first to pull it out and it started to back up????? Worked it thru the gears and it does not seem to want to go into reverse or second, but will go into first, third, fourth and fifth, all with the same results as wanting to go backwards. If if put it in neutral and give it some gas...., it wants to go backwards.
I moved the transfer lever to neutral and it acts like it's in neutral, but in high or low it will always try to go into reverse.
I apologize if my search ability is not up to par, I did do a search and just don't think i came up with my particular issue.
Any help would be appreciated!!
Ken
Ken
