yet another 109 MRV
m109guy
27
ON
Good to see another M109 joining the ranks. We need all the trucks we can for the up coming zombie apocalypse ;)
Good luck on the build!
T
televisionman007
Guest
m109guy i have a ? the black white and green wire, whered you hookem up to as im only installing one plug that will go either campground or my generator. i looked at yr conversion but no mention of wire config
m109guy
27
ON
Are you asking how to connect the wiring into the main control box in the back of the truck to supply power (110v) to the internal system?
No I didn't go into any great detail for things like wiring, as it would have make the conversion page like 10x longer, and most people are not really interested.
Let me know and I can see about posting some pics with the info.
T
televisionman007
Guest
yes im wondering which side is for the black and which side is white and do they go on to op fuse or bottom
m109guy
27
ON
Connect them above the fuses. Black to the left, white to the right.
Connect the ground wire (I guess green in your case) to the case of the box to ground things.
Ignore the rest of the wires in my pictures. They are for the rest of my electrical system.
Hope that helps.
T
televisionman007
Guest
Hope that helps.
thank you i thought it was that way but wanted to ask first
