Help please
wsmayeux
Carbonado, Wa
Alternator woes
Alright so,
Last week i brought home a 1984 m923a from gl in Tacoma. On the way home, i noticed that the volt gage was reading in the yellow. Huh... A little further down the road, the fuel and water gages started jumping like mad...... Now i new the batts were prob junk as i had to have it jump started there. So, i swung into wally world to pick up some batteries on the way home. i removed the old, had them tested. Two dead, Two weak. replaced batteries and started......Fires right up and .......gage in the yellow. i begin my inspection of wiring and find that the batt wire on the alt is fried at the connection. Well at the end of the wire because it was BURNED OFF. it appears that the wire shorted to the cover at some time. Looked to be awhile ago. So no prob i thought ill just fix the wire....got home fixed the wire and no go. still not charging. cjhecked voltage at terminal read batt voltage 23 volts. So with a little investigation i found that the voltage regulator was fried also. Ordered a regulator....waited impatiently for the ups man. Today the regulator arrived. I quickly installed it, reinstalled the alt and.........no go again!!!!!!! Dang. I then removed the alt again ang began further inspection. what i found was that the rotor windings are burn up also. If you look in the alt with a flashlight you can see them.... toast. dang.... Soooo does anybody know how much an alt rebuild costs????? Anyone in the Tacoma/washington area know of any good rebuilders? I alread found a 24 volt delco 1 wire for around 100 bills, but i just got this brand new regulator and id like to be able to utilize it one day, so i dont know if i wanna go the delco route. at least if i replace it with stock ill have a spare part..... please, any help would be great...i just wanna get out and drive this thing........ A couple of years ago i had a m35a2 when i lived in va. But alas we had to part when i moved to washington, so im really itchin to get this baby on the road and start playin. Its like therapy i think....good for the soul.
please help this desperate mv'er
Bill
wsmayeux
Carbonado, Wa
alternator
Alright so,
Bill
ps...i know this is a five ton, but i thought it might be relevent since they use the same alt.
rosco
30
Delta Junction, Alaska
The electrical system is a symptom of deferred maintenance, and that its not "street ready". The rest of the truck needs to be serviced, especially the brakes, to insure safe operation.
cranetruck
75
Meadows of Dan, Virginia
Congrats on your new truck and welcome to the site.
Do you have part numbers? Different alternators take different regulators.
Meanwhile, make sure you put a charger on your new batteries, don't let them sit at less than full charge for long.
wsucougarx
67
Washington State
Goto Brad's yard in McKenna, WA. He's got about 25 alternators sitting on a pallet. All checked and ready to go. He uses a Boeing engineer to go through his alternators. They are all used and NOT rebuilds. He only charges around 125 or so plus your old alternator.
goodguyzy
13
medford oregon
This is a very common problem. All military trucks sit and sit. The battery gets drained down or low and when the truck is started the alternator gets overworked. The alternators are the same in all newer 2 1/2 tons including m35a3 and "newer" 5 tons up to 900 series. I had one fry on my A3 right after I bought it and took it into a local shop that said they could rebuilt it for $700. I ended up buying a new SAW from eriks, it was pricey but I now it is new and a fresh start. Also put in new interstate 6tl's. Good luck, hope to see you at some PNW rallies.
73m819
325
gainesville, ga.
The title HELP PLEASE is the same as 911, somebody is in trouble, the title should be something like , my 5t alt. seems to have a problem NOT yell HELP, also this helps search
dmetalmiki
2,028
London England
WS>>>
Why the 100s of bucks to fit an over the top alternator?, Do you have machine shop/ 30 radios in back? no?..ok, well if not..chuck ANY 24 volt Single wire (to charge the batteries ONLY! ) Alternator ( from ye'r LOCAL scrap yard!) On your truck. I have single wire 24 volt alternators on MY KRAZ and two M series trucks., Cost? 25 quids EACH! (£25!) Go for it. ....(who the hecks gonn'a look under the bonnet (hood) anyway to say "oh , that's not orriginal!"
wsmayeux
Carbonado, Wa
Just to update....I contacted brad in mckenna and will be getting a mother alt from him on ties....thanks to all who actually had constructive things to add to the post. As to the others maybe you guys should come up with some other ways to fill your day instead of lurking on this site just to criticize people and there posts. Its really a turnoff to new people in the hobby. Ill keep you posted in how things turn out on tuesday.
thanks again
bill
Recovry4x4
LLM/Member 785
1,808
GA Mountains
thanks again
bill
I don't think the intention was to criticize you, more to guide you on the forum. Titles not relevant to the subject water down the search function greatly. We are trying to reserve the "911" and "Help" titles for those folks in dire straits via either mechanical breakdowns on the road or stuckage. So while you may think its criticizm, they are filling their days trying to help you and by doing that, it improve the efficiency of this valuable forum. I hope that seeing it from that perspective that you can appreciate their help.
Welcome to Steel Soldiers and congrats on a nice truck.
219
new smyrns beach fl
there was a guy in town that went on a trip several states away , posted help needed , the response was overwelming . had 5 sc members working on his truck , as grandma used to say, dont wear your heart on your shirtsleeve , keep on trucking :driver:
wsucougarx
67
Washington State
thanks again
bill
Glad Brad worked out for you. Yah, there are a few salty experienced guys in here. They mean well.
wsucougarx
67
Washington State
:cookoo::cookoo:
Uh, I care whats under the hood.
