mudman
- 10
- 0
- Carson City, NV
You might need to "Run the Rack".!!
do you mean just drive it?You might need to "Run the Rack".!!
Yes it does. you can hear the pump in the tank and the geyser we had coming out the bleeder was on the pump alone.With the truck not running, turn the master switch on and check to see if the in-tank pump is running AND pumping fuel to the filters. Could be the fuse or could be a bad hose inside the tank.
Valve adjustments!!do you mean just drive it?
Well that's good because i plan on driving the **** out of this (at least locally and as long as i can afford to feed her)One thing you WILL find, is that these trucks LIKE to be driven. Problems go away as the miles do also!
10 MPG for a 13K truck, isn't bad!Well that's good because i plan on driving the **** out of this (at least locally and as long as i can afford to feed her)
