Wrecker count
WHAT WRECKER DO YOU HAVE
  • M60
    Votes: 2 1.1%
  • M108
    Votes: 10 5.4%
  • M62
    Votes: 22 11.8%
  • M543
    Votes: 25 13.4%
  • M816
    Votes: 71 38.2%
  • M246
    Votes: 2 1.1%
  • M819
    Votes: 12 6.5%
  • M936
    Votes: 49 26.3%
  • Other Wreckers
    Votes: 7 3.8%
  • K-Booms
    Votes: 1 0.5%
zebedee
conceptualizer at large
703
Central NY
Wrecker that doesn't count?
It is a wrecker, but as it's under 5 ton I guess it doesnt count!
Only 6 in total were ever fitted this way, there were only ever two serving at any given time, new ones replacing the previous as required... as in parachute failure etc!
Used by 2 PARA, for front line recovery of light vehicles, dropped in by chute from C130s.
jets1959
9
Lakewood, WA
Way cool, it must be the rarest wrecker!:cool:
73m819
319
gainesville, ga.
If you owen it, IT counts, put it in as OTHER
73m819
319
gainesville, ga.
First -- the max number of choices allowed is already up
Second -- there are NOT enough m984s or m1001s in private hands to warrant a separate category, this is what OTHER is for
zebedee
703
Central NY
Hmmmm - so what does technically count as a wrecker? Perhaps the 'crane-tractors' should NOT be counted as wreckers either, or perhaps a fifth wheel 'underlift' would then make it count, or should it have to have ground spades to be a wrecker? A tank transporter with single or dual rear winches - perhaps they count too! Hmmmm - then there are the maintenance crane trucks, are they sort of wreckers???? Maybe it is only a wrecker if an H8 drove it when in service.....
73m819
319
gainesville, ga.
Hmmmm - so what does technically count as a wrecker? Perhaps the 'crane-tractors' should NOT be counted as wreckers either, or perhaps a fifth wheel 'underlift' would then make it count, or should it have to have ground spades to be a wrecker? A tank transporter with single or dual rear winches - perhaps they count too! Hmmmm - then there are the maintenance crane trucks, are they sort of wreckers???? Maybe it is only a wrecker if an H8 drove it when in service.....[/QUOTE]
Designed and Designated as a WRECKER by the MILITARY, Does not matter who drove what, self contained without having to add anything to corvert it
The m108 technically is the only one in the list that is not a wrecker but a BOMB HANDLING CRANE TRUCK, ONE reason it is listed because it is MISTAKENLY by many called a deuce wrecker, ANOTHER reason is because it is the REASON that the m60 came into being, the 108 was used for light recovery work as a side non-design use, so the great minds of the great thinkers saw this, and thought great since thay are using a bomb handling truck for a wrecker, WHY not build a deuce wrecker, the m60 is born, now everybody that got the m60 saw a wrecker, and a wrecker is wrecker, well as people found out NOT quite so, the m60, it turned out, was way to lite for general wrecker service since it was asked to do a LOT more then the m108 was asked to do, this was the death of the m60
K-BOOM was used by the CADANIAN forces as a light recovery vehicle so it has its own spot.
The "crane-tractors" or as the MILITARY calls them TRACTOR WRECKER (m246/m819) is a carry over from WW2 where thay had the Autocars and other tractor wreckers that was used for the recovery AND the loading of aircraft
