bridge plate numbers?
rumplecat
215
North West Arkansas
I want to restore my bridge plate on the M1008, what should they show? The top plate is for a trailer if I remember, I need that designation also.
Thanks
jkrieg
Central Indiana
The top plate with the "C" designates "Combination" meaning with trailer. The numbers indicate thousand pound increments. The numbers should read your total weight in thousands.
Matt65
Alabama
Originally Posted by M813rc
Okay, from my copy of FM 5-36 dated May 1985-
For our purposes here, the CUCV series is (fortunately) listed, the numbers are for empty, then loaded cross country, highway and combination -
M1009 2 3 3 4
M1008 3 4 4 5
M1010 3 4 4 -
M1028 3 4 4 5
M1031 3 5 5 6
M813rc
3,068
Near Austin, Texas
To get a weight classification, the following is used:
Weight (empty, loaded, and loaded for highway);
Load on pintle or 5th wheel;
Tires (number per axle, size and PSI);
Distance between axles;
Distance from nearest axle to pintle or 5th wheel;
Outside and inside width of tires or tracks;
Length of track in contact with the ground;
Vehicle NSN.
This all gets sent to STRBE-NBE at Ft Belvoir where they perform some ceremony that quite possibly includes waving an intoxicated newt around above the numbers and they give you the weight classification.
OR, you can look and see if they have already done their rituals and your vehicle is on the Standard list in appendix C-3;
or you can get a field expedient number by using 85% of the vehicle gross weight.
M1009 2 3 3 4
M1008 3 4 4 5
M1010 3 4 4 -
M1028 3 4 4 5
M1031 3 5 5 6
Cheers
