kamikazee
- 0
- 0
- Big Lake MN
I bought a 1028 on Monday (pictured) after doing extensive research on this site. I love the truck, I really wanted a diesel and couldn't believe I could get one with so few miles for so cheap. I'm actually still a bit surprised. It'll work out as a great truck for work (NOT my daily driver) and to get through snowstorms.
Anyway, one of the reasons it was so cheap is because I bought a bit of a rust bucket. I'm planning on getting some 1/8" or 1/16" inch steel and pounding out a plate to put over the rusted holes, after grinding the rust out and coating with rustoleum. Has anyone ever done something similar to this and have any details to share? I did a quick search of the forum and didn't find anything.
Also I have a small leak coming from the fuel tank. Haven't dropped the tank yet, but plan on using the epoxy to patch the hole (assuming it is a small pinhole leak, which I suspect it is). Anyone have and especially good / bad stories associated with these patch kits?
My wife also insists I paint the truck from camo to another color. I'll go with flat black (will help hide all the dents). Anyone have any good luck with DIY paints? I'd rather not bring it to an auto body shop and don't have the capability for a gun myself.
Is there any way to tell if there is a gasket between the tranny pan and the body? I noticed the tech manual said to use a gasket if necessary, but I didn't notice where it said which ones have gaskets or not. Maybe I'm just blind.
If it wasn't already evident, this truck is for function, not style, so if something looks a bit odd but still works, I'm open to the suggestion. It already runs well so after a few normal maintenance tasks it'll run perfect.
