Jayco36REQS
- 2
- 16
- Orlando/FL
I'm looking at either a M931 or a M932... which would you recommend getting? What are the major differences besides the winch?
Get the winch truck just in case you need it. If you have to ask the difference, your subconscious already knows that you will need the winch one.
It has been done but it ain't cheap or easy.Still not crazy about the 250 motors in these things, anyone swap a 400 into one of these trucks?
Get an -A2 with the 8.3 CTA.Yea I tend to get myself into "situations" where a winch might be useful! lol Still not crazy about the 250 motors in these things, anyone swap a 400 into one of these trucks?
Are they really that much better than the 250? I know the hp is around the same but the 8.3 does have a little more torque but I wonder if it's that noticeable (especially when you factor in the larger tires)?Get an -A2 with the 8.3 CTA.
Aren't the -A2 series equipped with the UNRELIABLE CTIS System?
The M931A2 that I have came with the CTIS removed and is the best running truck that I have. It will co faster, on less fuel, then any of the others.The CTIS is easy to disable.
As far as I know this is correct ,Aren't the -A2 series equipped with the UNRELIABLE CTIS System?
Are both -A1 & -A2 series Singled Rear Wheels vs. Duals?
Which engines in which series? and the pros and cons of each please???
Thanks.
opcorn:
