tgtaylor64
- 4
- 18
- Florence, SC
What are the advantages/disadvantages of these two types of starters on a M1008 (both 24 VDC)? I know the brackets are different. Are they interchangable? Any problems?
Trying to go all diesel or is the 396 just getting to pricey to fee?I will also be putting a 6.2 into my M715 and it could have a redux drive depending on where I find the starter for it.
One that worked every time I tried it. Beyond that I have no idea.I don't think I ever even crawled under the M1010 all those months it was here. What kind of starter did it have on it? I just know it started great.
I am currently in starter replacement mode for M1008 and this thread sounds like good info hashing I want to get in on--- Agreed--- the 28MT seems a better design no doubt but try to get one that is NOT either made or re-manned in China--- junk just I won't buy if I can help it--- good luck on that one!The direct drive 27MT was American made. The reduction gear 28MT was originally from Korea and now China.
I have had two 27MT failures. The first time I had just gotten the truck and didn't know the glow plug card was not working right. I thought it was normal for 5-10 seconds of cranking for every start. I had it rebuilt with all Delco parts. I didn't tell the rebuilder to be sure and use a USA made solenoid. Almost a year to the day of the first rebuild. The Chinese made solenoid stuck on and burned it all up again.
When I put it on after the first rebuild, I also had fixed my glow plug problems by then. The truck never took more than 1-2 seconds at the longest to start. Hot or cold.
That was the M1009. It starts so fast, I don't think a higher rpm starter could make any difference.
The USAF Suburban I have with the 6.2 engine starts just as fast. It has a 12 volt 27MT. However, it also has the civilian glow plug system. Which sometimes works and sometimes doesn't. I never let it go more than 5 seconds. Because I limit the time it is trying, the starter just keeps on working every day.
I wrote all of the above to prove my point. If your 6.2 has a good fuel system, a clean fuel filter, a properly working glow plug system with all 8 plugs glowing and a good starter in it now. The truck should start up in less than 3 seconds hot, cold or warm. There is no need to switch to a redux drive.
GM had bungled the civilian glow plug system so badly when they first introduced the 6.2 that by 1988, 6 years into production, they were on the 3rd version of it. Lots of people just did what they do with a gas engine. Floor it and crank until if fires. Diesel starters can't handle that. Lots and lots of people did that and the starter got a bad reputation. When they changed over to the 6.5, they did the reduction drive starter swap too.
Now I am the first to agree that in theory a reduction drive starter is better than a direct drive. However, when you outsource the production to where something made 10K miles away with more parts and more machining needed is still cheaper than the old part. Something had to be given up. I think they gave up material quality and tolerance control.
That is my current view. I am a few months away from getting another M1009 running that will be reduction gear started. I will also be putting a 6.2 into my M715 and it could have a redux drive depending on where I find the starter for it. I will be sure and post up if my view changes.
"The 'rebuilt' 27MTs often have a short life span."
Why is that? I would be interested to know.
Cheep components. shoddy work? If I has some good components, I might rebuild too. For a while I was taking rebuilt starters back to parts store repeatedly, getting 'new ones' still in warranty. On multiple trucks, that gets old fast. This was also the experience of an other guy I know who runs 6.2s in his work fleet. You can still find good gear reduction starters as well as the cheep ones. Have had pretty good luck with both, although the cheep solenoids fail sometimes, they are only $40.
I always keep at least one 12v and one 24v spare on the shelf. When your crew is waiting around on the clock while you to fix their truck, you go the quickest route. These days, I have the luxury of spare trucks too, but it was not always that way.
Remember to replace the starter bolts along with starter. When they fail and you are trying to install a Helicoil, you will wish you did.
