2012 Ga Rally parts wanted/for sale/swap thread
Ok, I am clearing out a bunch of excess stuff. Mostly everything is for deuce. Mostly everything is fair/average/needs work. Mostly everything is dirt cheap. Please save this stuff from the scrapyard.
To avoid cluttering up this thread - if you want something send me an email. Don't reply in this thread. I will reply to you and then mark the item sold here.
I will only bring the items that are wanted. So if you want something speak up or it will be left at home.
SOLD pctrans - Front Deuce springs, hangers, and axle saddles, maybe u-bolts. (Bobber kit) $250
Floor pans (deuce or 5-ton M39/800 series) any piece $1
Extended length rear Driveshaft for bobber. Home built by Previous owner. $10
Deuce engine side covers (fair condition) - $2 each
Unknown Side engine cover (too long for deuce) $2
SOLD pctrans -Deuce cab top frame (left and right window frames only) No crossbars. $2
Old style park brake handle $2
Headlight panel any piece $2
106_1142 (Small).jpg 106_1146 (Small).jpg 106_1179 (Small).jpg106_1178 (Small).jpg
SOLD Clinto - Deuce OVM toolbox, solid, but surface rust inside. No step plate. $4
SOLD Clinto - Deuce battery compartment, fair condition, no box, no step, $4
SOLD bigugh20 - Frame brackets (were from battery box support) Could be used to mount a tool box or additional fuel tank ? $4 pair.
SOLD pctrans - Deuce rear pintle hitch $25
SOLD 73m819 - Deuce spare tire winch $5
SOLD Clinto - Fuel tank strainer and Cap (needs cleaning) $2
SOLD ca1517 - NOS Hydraulic Cylinder - NSN: 3950-00-197-4935 The NSN lists part fits -Crane, Truck, Warehouse 10,000 lb cap, GED, PT Pettibone. Model: 10FM, MHE 216. It is roughly three feet long and maybe 4” bore. What do you want to build? $80
Composite Light Connector Cover (under fender)- $2
SOLD wilfreeman - 24v headlight with Douglas connectors $5
Wanted:
Wanted: Nice Yellow bridge plate top plate. This is the semi-circular tab that locks the numbers in place. Looking for a really nice yellow one.
I have several steel jerry cans – I want to trade for plastic cans . The steel cans I have all have threaded pipe spouts as shown. You can easily remove them for use with a flexible spout or use as is.
mikev
71
Culleoka, TN
NEED: Fuel transfer hoses
NEED: Fuel transfer hoses from the 24V slave cable driven 35 gpm fuel transfer pumps. I'll be bringing two to four of the pumps after I check them out for function and will sell them for what I paid GL.
Soon, I will revise my parts list and post some photos of some parts I'm bringing.
I will be bringing USGI issue Panasonic CR123A 3 volt batteries (for flashlights/weapons lights) - 10 per box for $10 a box.
I am still trying to get additional Hawker batteries; however, the 22 spoken for will be brought to the rally (don't forget your "wallets and cores")... :)
RIDDLE1
Americus GA
I will take 2 boxes of 10 batteries as well!
73m819
319
gainesville, ga.
WOW I have a lot of the parts ya'll are req here will need to unpack them and see what i have.
steve
I would NOT unpack just yet UNLESS you are going to the 12SSGAR and being that you ARE in CA., that would be about a 3000mile trip
bigugh20
Mt. Pleasant/ SC
Deuce exhaust stack (w/ clamp), fair condition, $2
Jeff, I'll take the spare tire winch, the frame brackets and the exhaust stack
Jimma
Hartwell, GA
I found a spare tire winch I can bring $5.00, the deuce driveshafts $10 each. Perfect for bobbing a deuce because you can still drive the trcuck while the spare is being modified. Rear mudflaps $10.
73m819
319
gainesville, ga.
I Jeff sells his winch, I would like yours, thanks
Recovry4x4
LLM/Member 785
1,807
GA Mountains
Folks, I have a set of 4 16.5x6.5 rims. Looks to be civilian equivilant to the M880 rims. Was going to put HMMWV tires on them but now getting away from that idea. $20 for the set or trade for chilimac. Not bringing them unless someone commits.
