KaiserM109
- 4
- 0
- SE Aurora, CO
Can anyone tell me if there is trouble titling a deuce if “Data Plate Has Been Removed”? There are a bunch like that on GL right now.
Arlyn
Arlyn
It lists serial numbers with the description, but what about year of mfg? That will be important since I probably want to license it as a collector’s vehicle. Also, I DON’T want to have to get a salvage title on it.Look on the frame for the serial # and get a new data plate and stamp the # on it.
NO issue whatsoever. We can figure the year by the VIN stamped in the frame.
Me knowing is one thing, but will DMV buy it all? It could wind up a parts truck.Get your bid on.
But ... There has to be an inspection. On my M109 a state trooper examined the data plate. It's been 4 yr. since I've seen an SF97 and I don't remember exactly how all that goes.Remember YOU provide the SF97 info to GL. DMV goes off that.
Inspection? In CO you have to have an inspection to title something? Most states you walk into the DMV with your SF97 and walk out with a title and plates. When you pick up your truck from GL, you are then able to apply online for the SF97. It is a blank form (HINT).But ... There has to be an inspection. On my M109 a state trooper examined the data plate. It's been 4 yr. since I've seen an SF97 and I don't remember exactly how all that goes.
I have my bid in, the question is will I follow it through if someone else gets interested.
I'm only willing to pay so much for parts.
BTW MY M109 RUNS!!!
Arlyn
