Finally engine out off the M1010
panzerwillie
254
miami florida
Finally got around to pull the engine out of the M1010 even do is being here for over a month when it blow up coming back from Alaska will take apart in the next few days to see what i can savage the engine only has 9000 miles after complete overhaul including new heads timing chain IP injectors balancer ect ect , for now here are some pictures of pulling it out using the wrecker;)
Warthog
240
OKC, OK
I would say there is an issue with the oil pan....:p
Looking forward to the autopsy results.
southdave
ripley, oh/TDY Lordstown,Oh
I am guessing a rod did that?? who did the overhaul?? the reason I asked, is because I just had 3 - 6.2 completely overhauled.. holy crap.. maybe I should convert all to cummins
mudman
10
Carson City, NV
I don't know who overhauled it....But they did not either check bearing clearance or passed up on the tork spec on the rod cap..Bummer I hope you can get your money back..Crappy job right there!!
Recovry4x4
LLM/Member 785
1,823
GA Mountains
Wasn't necessarily the builder, sometimes parts fail. Could have been pushed a little too hard in the mountains while towing as well.
Warthog
240
OKC, OK
It is all those yellow things that caused the problem. ;-)
Pretty clean break on the rod. That block is toast. :-(
