M146 RV Conversion
RAYZER
59
sanford/florida
Plumbing the Throne!! Got the holding tanks in, just a couple more pipes to hook up, run some water lines and the Throne will be ready to occupy!!
uploadfromtaptalk1357001693944.jpguploadfromtaptalk1357001723536.jpguploadfromtaptalk1357001760616.jpguploadfromtaptalk1357001813906.jpg
RAYZER
59
sanford/florida
Looks great brother keep it up. So how did you end up sealing the short tank where the sides were?
Yes. I had to shorten up the grey water tank to make it fit.
Cut 10" off the end of the tank, then cut the the very end of that off and stuffed it into the end open end of the tank,stainless steel riveted all around and sealed it all up with some bad azz epoxy, (will stick to abs plastic).
Good as new!!
uploadfromtaptalk1357007753148.jpguploadfromtaptalk1357007788462.jpguploadfromtaptalk1357007820927.jpg
Tow4
640
Orlando, FL
Wow Ray,
I didn't notice the twin Barca Lounger when I was there Monday; that's awesome! The way those recline, you won't be needing your air mattress any more. Plus it will be easier to sleep through the movie next time! :beer:
BTW, that is a cool MV parts storage/workshop you got going. You need to post some pictures after you get it painted. [thumbzup]
RAYZER
59
sanford/florida
Yes Ray, the double recliner is awesome!! No more air mattress thank goodness.
The 40' semi trailer is definitely an asset for my parts storage, ......and I painted it today!!uploadfromtaptalk1357101415769.jpguploadfromtaptalk1357101430240.jpg
Nick
Near Daytona Beach, Florida
Wow, I just spent about an hour reading thru this thread form post #1
I believe it was said in here somewhere already, adjectives dont do this justice. Amazing build. Makes me wish I had the room for the trailer and truck need to pul it, and the money to buy both. I do federal Excess for my fire dept, but Id never be able to get this big stuff living in a tract home in the middle of the city.
Thanks for letting me live precariously thru you Ray. Great job
Nick
RAYZER
59
sanford/florida
Thankyou for the kind words Nick, makes all the hard work on this project worth it when others enjoy looking at it!
For the past few days ive been busy working on and figuring out black and grey water plumbing, had to hole saw through 3 cross members to run pipe from the tub to the grey water tank, this worked out nicely! Here's some pics of the results.uploadfromtaptalk1357524980727.jpguploadfromtaptalk1357525009861.jpguploadfromtaptalk1357525028288.jpguploadfromtaptalk1357525062322.jpg
Tow4
640
Orlando, FL
That all looks good Ray! You need to test it thoroughly before it goes live. There's a long drop from the throne to the tank. You don't want to find out that when the bomb drops it sets off a tsunami that blows the drain pipe out the end of the tank! :shock:
RAYZER
59
sanford/florida
Yes Ray! That would be bad! Would that be a live test, or simulated test? I seem to be having anxieties about fouling up my new, unused waste system.:D
Danger Ranger
23
Roland, IA
STOP CALLING EACH OTHER RAY!!! You're making me crazy! You are both named Ray, and ray is short for Rayzer, ....I am so darn confused.aua Who said what??? Oh thats right, it was Ray.:doh:
AHHHHH! :soapbox: :hammer:
:rant: :whistle:
RAYZER
59
sanford/florida
Working hard to get all the plumbing functional! Finally, almost done!
Drainage system is complete with the exception of the bathroom sink.
All water lines run and hooked up!
Left to do: install gravity fill hose and vent line for fresh water tank, install bathroom sink and faucet, system test.
Next phase of this project: 120v wiring.
uploadfromtaptalk1358123955194.jpguploadfromtaptalk1358123979881.jpguploadfromtaptalk1358123998813.jpguploadfromtaptalk1358124012578.jpguploadfromtaptalk1358124024458.jpg
Call it a day.
