jeeplvr247
- 10
- 0
- Ferndale, MI
Once the weather warms up I am going to have a crack at painting the M813. I already have the patterns and I think I will free hand the CARC 3 color. There is quite a bit of surface rust on the truck and I am going to use an industrial strength power washer to take off all the loose paint and loose rust. I was thinking about buying the wand that will allow me to feed aggregate into the stream to take it down to bare, shiny metal. Is that necessary? I do not want to make extra work for myself if I do not have to.
Also if I simply power wash it to knock off the loose stuff should I do a layer of primer?
In the TMs I noticed that they say 1.5 gallons of paint for a five ton. I have not done much painting but that does not seem like a large amount. If a buy 1 gallon of primer, 1 gallon of CARC green, 1 quart of brown, 1 quart of black, and a gallon of thinner will that cover me for two coats of everything?
Below is a picture of the back of the truck where the rust is the worse so you can get an idea of what I am working with.
Thanks, If this goes well then I will start sand blasting my m38a1 and get her ready for fresh paint. I have counted 7 layers on that one already so my gas mileage will probably go way up after I take all that weight off
