richingalveston
- 120
- 63
- galveston/Texas
I spent a lot of money with LMC to insulate my rig with the behind the dash insulation, used the asphault base product and the carpet pad type product with the milar heat sheild on the floor on and then put the rubber floor on top of that. My 1009 is almost as quiet as the 2004 duramax I drive for work. I dont have to worry about the cold in texas but it does make a huge difference in sound. I hope to get the rear AC installed before it gets hot this year and the insulation will help the AC keep it cold.
I would not use the spray foam. you will just get a big mess and possibly some holes in the outer roof trying to drill through the inner roof. In the center there is less than 1/4 inch between the two pieces of metal. There is more space around the edges but none of it is thick enought to get enough spray foam to make a difference. Money will be better spent putting a civy headliner and trim in the ceiling. just doing the floor and firewall is all you really need for sound. The under hood insulation also makes a difference in the sound inside the cab.
