Here are the parts I picked up at Jeff's place Thursday:
As i was setting up to install the shackle bases on the bottom of the bumper I got the package with the LED turn signals I ordered. I bought them for less than $30 each. They do not include the housings. Had to take the metal cover off from the back of the fender to expose the wires and connectors. Unhooked the electrical connections and removed the 2 large bolts that held the housing in place. Unscrewed the lens and removed the guts. Installed the new LED assembly on to the housing and fed the wires through the fender hole. You will need to remove the grommet temporarily in order to feed the wire connecters through. I installed the ground wire on to one of the 2 large bolts and secured the fixture back. I plugged all the wires back to the harness and closed the back cover.
I did the same thing on the other side and then tested the lights. I was concerned that the turn signals would not work with all LEDs in the system. Surprise! They all worked great! WOO HOOO!
Here are pictures of the new Turn Signals: (will paint them CARC Brown when I get a chance)
Once I got the LED Turn Signals done I started to take off the long bolt that held the top shackle in place. It was in very tight! I had to use the 3/4" ratchet drive to loosen it up. What a pain! The other two 5/8" bolts were also in tight. My aching back! There was also a 1/2" bolt to remove. I ended up using new bolts for the bottom shackle and temporary back bolt for the top shackle. I will install the all-thread when it arrives.
I started on the 2nd shackle mount. The long back bolt and front bolts would not budge! Since my back was already aching from the first set, I decided to use the angle grinder to cut the bolts off. I was planning to use new ones anyway! It was a lot easier to cut the bolts off than unbolt them. I hate the fine thread bolts! They take forever to undo and wear me out in the process.
I installed the 2nd shackle on the bottom of the bumper and tightened the new bolts. I completed fabricating the locking system on the 2nd shackle and installed it. Looks good to me.. I also finished priming the tow chain and started to paint it flat black. I will install it tomorrow if all goes well. Pictures of the progress:
