Libby Welding corp 300 amp welder
AMGeneral
115
Connelly Springs, NC
Well,I figured I would start a thread posting up the progress on the 2 Libby welding corp 300 amp welders I won from GSA around 1/24/13.
Both units were listed as unknown completion or running status,and I did not preview them,and I ended up winning both for a very reasonable sum.
They are 300 amp 32v DC @60% duty cycle,both powered by 04A084 military standard engines with electric start,1 dated 1971 and the other 1975,one with 48 hrs and the other with 170.
Welder #1 did spin over by hand,the other did not, after some minor work I have both welders running and welder #1 welds and runs as it should.
AMGeneral
115
Good deal. Don't those function as gennys also?
Yeah,they have a 120V circuit as well,2 standard house plugs per each.
I had a Hobart 500 amp diesel welder mounted on a M353 trailer before,"welding shop,trailer mounted".
But I sold it several years back.
AMGeneral
115
Basically they needed a good cleaning,tune up,and fresh gas along with cleaning the fuel tanks.
The second welder just had some light rust on the rings from sitting.
AMGeneral
115
Just a little update, after I traded off 1 welder to Ferro, I am left with 1,and with some mild tinkering this weekend I have it back running. It runs and generates as well as welds now!
I hopefully will get to take it along on the trip to Florida to pick up the M920 in a couple weeks.
Just a FYI, the 04A084 engine uses the same "double hump" mechanical fuel pump as the 2 cylinder M274 mule, an Airtex 73105.
