1) You will need a vacuum switch google search "f-4200 vacuum". Some are adjustable, some non-adjustable, and different fittings types for the switches. The vacuum switch is to turn the vacuum pump on/off. ~$30
2) Buy a standard automotive relay for turning vacuum pump on/off. Reason: the vacuum switches can't handle the current of the pump. ~$5
3) Buy a second hand electric vacuum pump from ebay. VW or Audi pump. You do not need the control module. (wire direct) ~$60
4) Buy a small check valve to go in between pump and vacuum system. ~$5
5) Optional: buy a vacuum accumulator from 80's chevy truck. AutoZone new ~$15
6) Buy hoses, reducers, adapters, wire, etc...
For 24v systems, you can pick 12v from the jumper cable between the batteries. Do not mount the vacuum pump to the sheet metal, fire wall, fender, etc. The noise will be out of control. Make a bracket to mount the pump to the frame or the motor. the accumulator looks like a plastic ball and will keep the pump from cycling constantly.
