- 3,923
- 75
- 48
- Comfort, Texas
Spending a good amount of time in the shop and getting little done. Did get the cab bodywork and painting finished. Installed the dash pad on the firewall as well as the Radio Interference Filter and starter plunger and side kick panels. Also cleaned and painted the regulator and associated hardware and mounted it with the wiring junction block and choke and throttle cable guide. Also, cleaned, painted and installed the rear drive shaft. Then the project took a dump when I learned my tranny has a crack in the housing causing a leak. I have a lead on a used transmission housing so we will see what developed. This vehicle may just end up at the CAMO compound as a static display.
By the way, I installed the cowl vent seal using that 3M adhesive that Zout recommends. Have been using it for some time and got two of my fingers stuck together two years ago. It is so good, they are still stuck!!!!
