3panther
- 0
- 0
- Wayland, MA
So my original 28MT cracked the nose 3 wks ago. I used a Direct Drive Delco model as a replacement and it only lasted a week, couldn't handle the torque. I returned it and ordered a rebuilt Gear Reduction from DB Electrical- looked good and worked for 3 days, then the original starter relay blew. I replaced that with the Doghead relay conversion, cranked it up and the starter continued cranking, even after I pulled the ignition key. Only way I could stop it was to pull the negative terminal on the front battery. Does this indicate that the solenoid is stuck open? I figured when the relay blew, it blew the solenoid.
