Mntsnow's recovery and building of The Beast
MtnSnow
14
NSL, UT
Here is the truck I'm getting. Needs front tires inflated. Currently arranging for transportation of it as I'm leaning towards just having it hauled to me. As such I could use (and willing to compensate) loadout help from Fontana next week. But it starts, runs smoothly and drives in the video so getting it onto the hauler should be pretty easy. I'm stoked. This will go good with our mountain property and will be great at some of our local car/truck shows
Coffey1
497
Gray Court SC
Welcome to the 5 ton club nice truck.
When you get it you might want to move those flats to the rear.
MtnSnow
14
NSL, UT
Thanks for the welcome and Yes they will be immediately moved to the rear most position upon arrival and I have a lead on a couple of spare tires locally as well :)
MtnSnow
14
NSL, UT
Yep that's what I'm guessing from 700 miles way. Hopefully it will be a easy fix. worse case I'll just do away with the ctis and just use a gladhand
Bighurt
46
Minot, ND
Personally I don't think CITS is really necessary in the civi sector. I would just take disable it and never look back.
Gladhand hose is one option, we had a few trucks with air chucks on the tanks. It's not authorized but very effective. We had one glad hand fitted hose and about 30 others...just made sense. I plan to do something similar but mounted somewhere cleaner neater and out of the elements.
wreckerman893
Possum Connoisseur
15,626
2,038
Be very careful removing the CTIS to change the tires. Many of the parts are made of "unobtanium" and would be hard to find on short notice out in the field. They are brittle and break easily if that 500 pound tire bangs up against them. We had to call a guy to change a CTIS tire at Redstone last year. The tire tech that came out said that if we hadn't been there to give instructions he would not have even tried to change the tire.
MtnSnow
14
NSL, UT
That makes me even more likely I will just have it trucked then.. Worse case they can load it with the flats and I'll just deal with it here at home.
Piper Cub
Palmdale, Ca / Flagstaff, Az
Another option is an air hose off a M105 trailer with a female quick connect put on the non gladhand end to make a short adapter hose. The threads on the hose and the quick connect are the same.
Gunzy
66
Roy, Utah
Mike, leave it solid green, that's different. Oh, and I would probably get rid of the CTIS as it can be problematic. Nice truck. When you get ahold of me next week you'll have to let me know what you got it for and shipping cost. Great score though.
jesusgatos
on the road - in CA right now
I think you guys are all crazy for disabling the CTIS! We've probably had about 15 A2's now and not had a problem with any of them. Sure, 4-5 have had a few small/slow leaks when we picked them up, but we haven't even had to dismount a single tire to fix any of them. Seems like a pretty reliable system so far, and it's having the ability to air-up/down on-the-fly is awesome. Someone made a comment about it being unnecessary, and maybe not, but it sure is nice!
Bighurt
46
Minot, ND
I made a similar comment, and clearly there are motives for and against.
If I was making an expedition rig, where I'd be in the middle of no where, on trails where airing up and down was necessary than sure. But my trucks park in front of my shop with 100's of airline feet and and return everynight. They also live on pavement and maintained dirt roads. Your situation maybe necessary, clearly the use depicts the need.
MtnSnow
14
NSL, UT
Well the CTIS seems to be working. (Paul) my hauler who has transported a bunch of these trucks said both of my front tires were deflated as it was probably doubled on the same step-deck trailer when it was hauled to Fontana as he was able to air them right back up with his glad-hand and they were still holding air and were fuller after I ran the truck today when he dropped it off to me this afternoon.
I'll give you a holler soon Gregg. I did ok on the transport costs and I'm very pleased with what I paid for the truck including fees and taxes.
