M871 / m872
Artisan
227
CDA Idaho
Guys would these statements be true?
An M871 is well suited for a M932 tractor
An M872 is well suited for a M916 tractor
An M871 can be pulled buy an M932 and M916
An M872 can be pulled by an M932 and an M916 but it is over kill and better suited for an M916
TIA!
4,820
If you want the trailer to ride level, you'll need to pull them with a m915. You can definitely feel the weight of the m871 when pulling it with an m931/932.
Having dragged my M871 back with my 931, I would agree with this statement. Even unloaded, hills were noticeable. :(
NDT
6,537
Camp Wood/LC, TX
Don't forget the M916 and M920 have the fifth wheel plate for the large pin. You have to change it out in order to couple to the 871 and 872. The plate is an $850 item and the p/n is listed here somewhere.
M1075
Oklahoma City
The M871 and M872 are very well suited for the M915A1. Neither are well suited for the M916. The M871 is well suited for M931 in lower speed and offload environments.
Artisan
227
CDA Idaho
...and what Mil trailers would be well suited for an M916?
Additionally is there someplace in the TM or other-pace I can read this stuff?
Thank YOU!
NDT
6,537
Camp Wood/LC, TX
Thank YOU!
Bighurt is correct but mainly the M172A1, in that combination it is known as the "LET" or light equipment transporter, if a Cat D7 can be called light. That is what is mainly transported in engineer units.
Artisan
227
CDA Idaho
Thank U both..
There is probably a list somewhere that someone compiled listing what woill work with what.
Wish I could find it. This is a good start.
zebedee
conceptualizer at large
736
Central NY
The -10 TM (operators manual) for each truck, will state applicable trailers.
eg. TM 9-2320-363-10 for the M915 A2, M916 A1 & 'A2, ...in Characteristics 1-9 it states:
M916A1 & A2 is used for the M172, M870, 60PRS and WD6S semi trailers.
M915A2:- M871, M872 and M1062 semi trailers
Artisan
227
CDA Idaho
Thank U Zee!
I have been pouring over the tm's and found
a little info but there are a lot of combinations
that have to be considered.
Bighurt
46
Minot, ND
Zee, beat me to it cause i can't log in at work.
However the TM isn't all inclusive, there are most liekly trailers you can tow that aren't listed. There are also caution's against certain trailers
11Echo
92
CT W. R.
The M870A1 is a versatile trailer with a 40 ton payload and not overwidth.
Bighurt
46
Minot, ND
Can't log in at work?
The system at work doesn't allow me to login because of its internal security system. In a given day I see "blocked" in all its forms a dozen or more times, mostly messing around but collage pages, aerospace websites, and even a few DoD sites get blocked. They are so few manned they just block everything and thus have less to watch.
He works for uncle sam.
At the moment...
