LDT-465 rebuild
wb1895
17
Lexington NC
I am looking at rebuilding the LDT in my deuce as soon as it warms up some. As she sits now she has ALOT of blowby several leaks, and most of the hoses are swollen. I have started getting NOS parts to get ready for the build.
So far I have acquired the following parts
New piston sleeves w/ pistons, rings, oil squirters, and wrist pins
New rod bearings
New Main bearings
New Valve guides
All Gaskets
New hoses
All new filters
And a guy that is gonna magnaflux the heads when I get them off.
Is there anything else that I will need?
Second, After I complete the rebuild is there a "break in" procedure I should follow? I did search the TM's but was unable to locate anything about breaking in a motor.
wb1895
17
Lexington NC
Make sure you let me know before you start it, I'd love to come help.
I don't have a date yet, but I am gonna wait until it is a little warmer so my butt wont freeze into the mud. As soon as I get a date I would be glad to have you come up. I might even provide the frosty malt beverages :beer:
1,128
I'd buy a new cam and lifters.
You obviously will have the crank checked and turned/polished if necessary.
I'd have the reciprocating assy. balanced.
I've never paid attention to the multifuel harmonic balancer, but if it's like everything else and has a rubber ring holding the two halves together, that can dry out and the balancer can fail.
You need to clean the block properly. I'd let a machine shop vat it. Prep it properly so you can put some high quality paint on it.
If you haven't done the clutch before, consider it. It's a lot easier to do it now than when it's under the truck.
Paint the engine compartment while the engine is out. This is also the time to rebuild the steering box.
DieselBob
13
Arnold Maryland
I know one thing I would put on my list of components to replace if possible would be the rod bolts. I remember there being a post about someone trying to get them made but I don't remember the outcome. I would defiantly have the rods magnafluxed and as Clinto indicated having the rotating assembly balanced. Might give some thought to setting up a pre-lube system.
1,128
I forgot the rod bolts. I am so used to sending rods out to have them "rebuilt" (resized, rod bolts replaced, etc.). You may find buying new rod bolts to be difficult enough that buying new rods is a better bet (but let your machine shop balance them obviously).
In terms of breaking it in, if it has moly rings, the rings don't really require break-in, but the cam and lifters do. You need to cover the cam lobes and lifters with a molybdenum assy. lube and when you start the engine, run it at something like 1500-2000 rpms in order to "spin" the lifters in their bores and get a proper wear pattern from the get-go. I'm having to guess at the rpm's since I've built plenty of gas engines but never rebuilt a diesel.
welldigger
15
Benton LA
Hercules sells the upgraded rod bolts. But if you can find new rod assemblies for a reasonable price that wouldn't be a bad idea either.
wb1895
17
Lexington NC
I was planning on doing a "in the truck" rebuild. I do not have a way to remove the motor, so I planned on rebuilding in place. Not the best way to get it done, but that is what I have to work with. Oh, and I am a VERY poor guy and am doing the best with what I have.
ATPTac
Charlotte, North Carolina
Oh c'mon Walter, we can muscle that engine out of there! They only weigh, what, 1800lbs? I actually do have access to a 2 or 4 ton (can't remember which) cherry picker, but I'm pretty confident it won't go high enough to get it out... Unless someone else can weigh in who has used one?
wb1895
17
Lexington NC
Really I would love to pull the motor and work on it like that, BUT I am poor and can barely afford the parts I already have.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Once you pull the radiator and take the rims/tires off, the truck doesn't need a lift with THAT much reach.
ATPTac
Do you think a normal cherry picker with a heavy enough load rating could pull the motor?
If so, I can see what I can come up with as far as getting one to take up there if you want... Or if you just want to do an in frame rebuild that works too. Just trying to give you options.
