So there's no part of the splined section in the hub? Both axles like this? It's hard to tell, but it looks like that's a torch cut with a freeze plug or dust cover placed into the center? I'd assume it was done on purpose to free up the front end. Which on a 5 ton is pointless since the t-case is going to apply the sprag in a M809 series truck.There was not one ounce of metal in there clean that way
The other Cap is the same they have torched the splines out and put dust caps over the holes like patracey mentioned . This truck is new to me I did a quick inspection drove it home 30 miles now just fixing . Amazing this seems to have been done buy our good ole Canadian military after they put the knuckle boom on it . :banghead:I can not see it from the pictures , maybe some either Torched it out or used a DIE grinder to take the splines . If there is no metal in the cap or bearings ,just need a new cap . BTW , how is the OTHER side ? Have you had the a problem with the front wheel drive operating ?
Your looking at a complete front axle service or by the time your done it might be cheaper to replace the whole axle.Thanks rtk
I should have taken it all apart here is what I have on the other side I checked for end play and the end just slid out groan View attachment 475981View attachment 475982View attachment 475983
