Ok guys, I have a busted inner seal on my rearmost rear end. I'm going to order parts to replace all seals on the rear end, so driver and passenger side (figured what the heck while I'm at it
might as well do the whole thing).
so correct me if I am wrong but I will need:
2x shaft gasket
2x lock washer
2x inner seals
2x outer seals
2x cork plugs
is this all correct before I make the purchase? I know I will need to inspect the bearings, and will repackage them if they are good.
thanks!
2x shaft gasket
2x lock washer
2x inner seals
2x outer seals
2x cork plugs
thanks!
