Hummer wheel lug bolt pattern, fit M880?
gringeltaube
Staff Member
2,520
Montevideo/Uruguay
Yes, both vehicles share the same bolt pattern: 8 on Ø6.5"
You are aware that the HMMWV-wheel has about 2-1/4" more backspace than the M880-wheel..?
G.
MWMULES
349
DESOTO, KANSAS
Yep both ends, due to the offset tires will not clear the rear springs. Got mine online they were both sold as used sets on Ebay but you can see in the picture it wasn't used long. I have also seen the 36's mounted on the stock dodge rims w/o the run flat.
Bob H
160
Huron National Forest, Michigan USA
.............................Do the 36's work well on the M880?
Your word "well" is an opinion, they do work.
I was the 1st one to make it up this hill, got bored waiting for someone else to make it so I took the pic of it sitting there. Another M880 with the 9.50-16.5's was stuck at the bottom.
an add a leaf up front helps.
MWMULES
349
DESOTO, KANSAS
Just put in Dodge 8x6.5 Wheel Spacers, it was years ago but less than $150 for all 4. Mine is a M885 so has the extra springs for carrying a shelter.
