4" Electric Exhaust Dump on M925A2
74M35A2
330
Livonia, MI
Ordered 4" cut-out from DMH performance. Having the wye pipe TIG welded into the exhaust pipe along the straight run below the passenger side floor, before the muffler but post-turbo. Undecided where to run the short dump pipe to.... Marking and removing pipe this weekend, and dropping off for welding Tuesday. Stay tuned.
74M35A2
330
Livonia, MI
Easy, just open or close the valve after it is installed. The DMH valve was supposed to have the best design, sealing, and warranty of them. When I hold the valve up to a light, I see zero light shining through. The butterfly actually seals against a ledge on both sides. I had an M35A2 for a week, and miss the sound of being unmuffled. But, I wanted silence on choice such as with family or a long trip. Others say it quickens turbo spool and lowers EGT. We'll see about all of that. Probably just going to run a short 4" piece of stainless curved to exit just flush and under the passenger side rocker area.
VPed
307
Clint, TX
Perfect for blowing smoke in the driver's side window of a car or pickup sitting next to you:)
doghead
4 Star General /Moderator
1,179
Heck, why not pipe it directly into the cab for the loudest possible effect.
doghead
1,179
You want funny?
I was gonna add to that, then you can roll down both windows half way and have "dual" exhaust (look like stacks from a distance)!
