212sparky
- 38
- 48
- Monroe/ Ohio
Are we wanting to do movie night this year? I can bring the A/V equipment again if the group is interested in it.
Movie night might be cool.... whatchya thinkin'....? Full Metal Jacket, Platoon, Rambo....? Cause those boring instructional videos are kinda like a people repellent....Are we wanting to do movie night this year? I can bring the A/V equipment again if the group is interested in it.
If you still have a empty cord, i would like to plug my trailer in again this year.. let me know... thanksDo we want another movie night? Let me know so I can bring the A/V equipment. Generator will be set up in roughly the same area. I have more infrastructure for power distribution. If you need special connections for campers or a welder let me know abd I will try to make provisions.
yep.. i'm scard.. lol i will be more then likely pulling less then 20A 120V but there is a slight chance it will get re-wired to 240.. will that be a problem? if so, i can just keep it as-is for the rally..How many amps? Normal 120 volt 20 amp line? I can accomodate that. I have completly overhauled the power distribution system I have. Be afraid, be very afraid.
No just let me know what style plug you need on my end. Adee you going to be parking in the same place? I am setting the genset in roughly the same place.yep.. i'm scard.. lol i will be more then likely pulling less then 20A 120V but there is a slight chance it will get re-wired to 240.. will that be a problem? if so, i can just keep it as-is for the rally..
I would LOVE to park in the same spot as the fall rally, but being as it is first come-first served, we will see how it goes.. I will be getting there around 6 or 7 wednesday evening.. and as far as plugs.. on one box like i used last year, is there 2 legs of 110 on 110 outlets in the same box? (is in, can i use 2 normal 110 plugs, to feed 220 into my breaker box?)No just let me know what style plug you need on my end. Adee you going to be parking in the same place? I am setting the genset in roughly the same place.
You can do that or I can give you a 30 amp 120/ 240 volt twist lock that will work with bigger gas ganerators as well as my spare cord I have.I would LOVE to park in the same spot as the fall rally, but being as it is first come-first served, we will see how it goes.. I will be getting there around 6 or 7 wednesday evening.. and as far as plugs.. on one box like i used last year, is there 2 legs of 110 on 110 outlets in the same box? (is in, can i use 2 normal 110 plugs, to feed 220 into my breaker box?)
that might work as well.. i just got my hands on a 4kw onan tonight, hopefully I can get it running pretty easily (might just need carb cleaned) but it is made to be hard wired.. so I will look for a plug.. or I have a transfer switch I might wire in.. either way, we will figure something out..You can do that or I can give you a 30 amp 120/ 240 volt twist lock that will work with bigger gas ganerators as well as my spare cord I have.
Ok, I will bring spare cable as well if we need to do some wiring.that might work as well.. i just got my hands on a 4kw onan tonight, hopefully I can get it running pretty easily (might just need carb cleaned) but it is made to be hard wired.. so I will look for a plug.. or I have a transfer switch I might wire in.. either way, we will figure something out..
If your power distribution system destroys my induction burners you will have many hungry folks very unhappy with you. Just thinking.How many amps? Normal 120 volt 20 amp line? I can accomodate that. I have completly overhauled the power distribution system I have. Be afraid, be very afraid.
It is the same as what I had last time. Just bigger, more panels, bigger conductors safer distribution.If your power distribution system destroys my induction burners you will have many hungry folks very unhappy with you. Just thinking.
That is all.
You could, might be a bit lonelyCan't wait can I go tomorrow?
