ke5eua
- 41
- 48
- Baton Rouge (Central), LA
I don't think so.Did some of this thread disappear?
How much. I am in need of a new seat and I was eyeing golden's springers he took out.If you want an air ride seat, I have a brand new drivers-side one that you can pick up at the same time as Recovery's bed.
I know right. If I can get the truck at my grandparents tomorrow evening then I will go, if not and I can get it there by 8 then I'll go, after 8 probably not.I'm leaving here at about 6am Saturday morning but you can ride with me if you want. This would be a lot easier if you just put your tires on some bolt together five ton rims.
I'd end up driving myself, visit my uncle in Conroe while up there.After 8? I'm leaving here early Saturday morning, so unless you are going to drive yourself you would probably need to be here tomorrow night and stay in the guest room so we could leave in the morning.
Yes the 395s will fit.
I know, just want to make sure the truck is out of the way first.Ok cool. Just wanted to give you the option to ride along.
They add something, aggravation right now. Value as in money spent, lolPersonally I would consider trimming the brake backing plate to remove the interference. Those aluminum rims are special and add value to your truck.
