Today got the truck running and moved it to the farm.
My pumps were DOA so I put the fuel hose back on the ip from the filter and did something I hate to do. I used starting fluid to start her.
I ordered a lift pump that goes on a 5.9 Cummins and I will tie into the system when it comes in.
I'm also going to marry the two tanks together and take out the fuel tank selector valve out of the mix. Teeing both feeds together and both returns together.
I'm ditching the hole using the bench seat base idea and taking everything out of the cab when the weather decides to cooperate. Batteries are going to go back in the stock box, equalizer is going on the back wall, and a M1070 seat is on it's way (NIB).
Will get my custom wiring done when I get everything out and my center radio organizers get in.
Have 2 90 amp solenoids on their way, 1 50 amp circuit breaker, 10 20 amp, and 3 30 amps en-route.
There was something I was trying to figure out with the VIC-1 but it has slipped my mind right now so it must not have been that important.
I did notice I defiantly need new window seals and I could have taken a shower going to the scales and to the farm. Also need a new wiper blade as it flew off.
Weighed in at 19020# with me in it. So I figure that is roughly 18700 truck, 200 me, and about 100 pounds of tools in the cab. Now if I could shed 2500 pounds I would be able to put a disabled vet plate on it.
