zout
- 154
- 63
- Columbus Georgia
Once its all figured out - we can fill those top radius end caps to make it a little more asthetic - instead of big suction ports.
That is the current plan hopefully will have soft top done also.Looks great Swiss. Are you bringing it to the Rally?
The panel adhesive was used to glue in a part of the roof that we had cut out to make the lip thicker on the front edge. This was for mounting the snaps for the cover. There really was no voids in the top from the cut. The short top is going to be shaped some more once the roll cage is complete.Cool project. Do I understand correctly that the panel adhesive will bond glass to fiberglass? It looekd like you used the panel adhesive to fill in the voids made from the chop. Why didn't you use something cheaper like fiberglass resin?
That is correct no touchy or I will assign you to the rock removal gang!I also got stern orders NOT to TOUCH anything till his return (huh).
