Covered M1102
Shark Bait
59
Charleston, West Virginia
image.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpg
I needed a covered trailer for an upcoming work project and decided one of my M1102's would be the perfect choice. Still gotta mount the spare tire carrier on the front in replacement of the Jerry can holder. Will post more pictures afterwards.
Dave
Shark Bait
59
The sides are framed with 16ga 1" square tubing. The top cross supports are 11ga 1" square tubing with a slight upward bow. The top is 11ga sheeting, the sides are 16ga sheeting, front and rear is 14ga sheeting and door is framed with 16ga 1" square tubing covered with 16ga sheeting. All steel, with lift shackles. Covered with spray on bed liner inside and out then rattle can rust oleum camo paint. Weighs in right at 500lbs.
FloridaAKM
392
Gainesville, Florida
I have seen anchors & bows for sale, but no actual covers anywhere. That is probably a factor why the Atlanta M1102 trailer w/ bows & cargo covers prices were so high this past week!
OK, that is sweet! I need this for our Cub Scout trailer. I can't find a cargo cover and bows.
I sent a PM.
Bill
ghostcrab
Jacksonville Beach Fl.
You hit that right on the head, I backed off all the covered units cuz it was getting to rich for my little crews budget.There was one camo cover that I inspected that was new out of the box!! I stayed with that one a while longer but had to bail after it hit the 6"s
PATRIOT1
Southeastern Ohio
Dave,
Great job - wow! Did you use the existing threaded holes on the flat top of the trailer to affix your fab'd unit? I see a clamp, which makes me think you went for the permanent install, with sealant, etc... Nice.
Shark Bait
59
Dave,
Thanks, the clamps were temporary to keep exact location to weld the mounting brackets. They attach using the original threaded inserts. It is sealed with truck cap weather stripping between bed and topper. I will be wiring up lighting inside along with a solar charger for a small sealed battery to run interior lighting.
Dave
FloridaAKM
392
Removed unnessary garbage from a quality thread of real substance!
wvu dodge
Fairmont, WV
Man thats some nice work. I like how you flanged the recess around the back hatch. Makes it more weather proof, but its also one of those little details that kind of shows off the skill and amount of thought you put into it.
You said you used foam gasket for the joint where it sets on the bed, but did you ever consider building the framework flush with the bedsides, and dropping the sheeting down an inch or 2 past the flange? Just curious, but it may look a little strange, and now that I think about it, when you lift the hood off and set it on the ground when you aren't using it, it would be sitting on thin gage sheet metal instead of the frame.
Very nice.
Shark Bait
59
Very nice.
Yeah, originally we were but yes, sitting it off would damage the sheeting. I got my lift struts on the rear gate this evening and the spare tire rack on. I'll try to get pictures up soon.
Dave
