Finally !! scored a hmmwv m998, LOTS to learn !! let the fun begin !!
Retiredwarhorses
4,127
Brentwood, Calif
Correct for that pump is
0432217092....0430211054...NA51X...0SD253....126 bar......6.2L Short body
but that depends on your heads....but I assume you got your reference from an exsisting injector.
so, put those in...and a new pump.
Stonepicker1
77
Coconut Creek, Florida
Standyne Injectors (New)
37818 10233973 6.5L T.D.
This is what I installed in two of my CUCV-II's(6.5L Turbo).
38272 10233972 6.5L N.A. same as 0432217275 6703802
This is what I installed in one of my CUCV's(6.2L).
All injectors were new and have not had a problem with them.2cents
Retiredwarhorses
4,127
Brentwood, Calif
A 6.2 has it in the casting on the front pass side near the water pump...also, no crank position sensor hole
on driver side down near the harmonic balancer....
auctionaddict
15
blue ridge, ga
Still not running, but close I hope !!
All I need are the injectors that should be here tomorrow !
Here is what I have done so far,
Rebuild pump
Rebuilt injectors
Rebuilt radiator
New fuel pump
New ground upgrade
New water pump
New fan clutch
New glow plugs
New smart start system
New batteries
New belts
New hoses
New filters (all)
New tires (stolen from my 1101s)
New 4 man soft top kit
New skid plate kit
New hub seal kits
New dash and gauges
4 new Mastercraft MRAP seats with harnesses
SW CARC paint (not painted yet)
Led headlights
Led master switch
Led tail lights with cameras
Led turn and marker lights
Also picked up a Complete slantback kit with x doors
Working on custom safari doors
To late to turn back now !!!
Got to have her ready for GA rally !!
My fuel filter !
Pablo66
Grants Pass, Oregon
Rebuild pump
Rebuilt injectors
Rebuilt radiator
New fuel pump
New ground upgrade
New water pump
New fan clutch
New glow plugs
New batteries
New belts
New hoses
New filters (all)
New skid plate kit
New hub seal kits
New dash and gauges
Led headlights
Led master switch
My fuel filter !
Loving those Safari doors! Are you planning on mass producing them??!
I've been working on a 1987 M1038, but your project seems to be moving along much faster than mine!
Augi
42
SF Bay Area
Be careful with the MRAP seatbelts. The floor of the HMMWV isn't really strong enough to hold the combined force of a person and the seat (especially in the rear, where it's just a couple of clips retaining the seat pan) and you can rip the whole seat out with you still strapped in during a collision.
Augi
Retiredwarhorses
4,127
Brentwood, Calif
Augi has a good point, the HMMWV seat belt system is anchored into the body with backing plates.
the seat on the battery box and rear seats could be torn out with just pulling hard enough on them.
the battery box cover is only made of fiberglass....personally I wouldn't run them for safety sake.
