Today I got the new box wired, tomorrow and Tuesday will be the relays and Wednesday the truck will be alive.
All switches were supposed to be off, looks like I left the fuel pump in the on position.
Battery switch on, illuminates the bottom light on all the switches.
All switched but the power switch in the on position. This shows that the fuel pump, and engine start need the power switch to be on to operate.
All switches in the on position
Battery switch in the off position with all the rest still in the on position.
Basically one main 12v positive comes in to the battery. Each switch then has it's on independent relay on the electronics panel to handle the load instead of the switch. This also made it easier to have all the switches on one voltage and have the relays handle whether or not it need 24 or 12 passed through it.
The battery switch is going to replace the dash battery switch, and the power and engine start is going to replace the run/start switch.
I have some more switched on the way from the outback to fill the holes and replace the red radio switch with a green one.
The radio is my 900MHz radio, Kenwood TK-981. The two you see in the background, top one is the ID-880H, and under it is the FT-857D, and the Dell laptop sitting on some cans of peas, lol
