- 1,127
- Athens, Ga.
A. Horn wiring is in the column like a deuce.I do not know if the dash factory horn wiring is still in place. I have not reached that point in the project...yet. However the under-hood sections of the horn wiring are still there.
On the battery question:
I had read that online during my research but I am always weary of trying stuff I read online without first double checking the information hahaha.
That would make life A LOT easier...and clean up the battery box. So I can keep both batteries hooked up to the vehicle wiring and charge each battery individually using a 12v charger...correct?
B. Yes, I'll try to remember to take pictures tomorrow. But go do this trick with your multimeter:
Put the positive lead on the positive terminal of the 2nd battery. This is the positive terminal that the battery cable is hooked to that goes to the starter.
Now, put the negative test lead on the negative terminal of that 2nd battery. Note readout. Then move the negative test lead to the other battery negative post. Note readout.
