- 14,258
- 1,759
- Dayton, OH
And you were worried.
Which front cross member do you have? One is bolted in, one is riveted in.would you still recommend pulling the engine and transmission at the same time? (LDT motor)
I am about to do this "on my own" with no soldier B, no skid steer, renting a skytrak (telehandler 5.5k),.
should I plan on a one day or week long rental....
Searching got me here (at 3am) so i'm doing my best, but looking for advice.
Great...No, you can take it out as a unit either way, it is just much easier if it un-bolts. I recommend pulling the top of the transmission off and dropping the oil pan if its the riveted one.
Great...
i'd really hate to take the pan off a new motor... uggg..
In my 1988 Air Force M35A2 I had to remove the front springs to get to the bolts. I replaced them with 1/2" stainless steel ones.Even with a bolt in cross member don't you have to remove the front springs at the front to grab the nut at bottom , that's what we ran into in Andy3's
I heard this one on the rumor mill that the GM "SM465" 4 speed transmission with the 1-1/2" input shaft will fit the deuce. I don't know since I never tried it, but you might check it out.Gimp,
sorry to ask, but i'm still trying to find out if the clutch alignment tool from a Chevrolet C40-C70 truck, will work on the LDT 465....
I found that in a search but could never confirm, I thought maybe you've heard this before.
That would be better than a broom handle and electrical/duct tape.Couldn't a guy with a wood lathe (or a metal lathe) whittle up a clutch alignment tool? You just need to provide the pilot shaft and clutch disc spline's minor inside diameter. Hardwood would be best but even pine should work fine. 2 cents.
