goldneagle
- 1,007
- Slidell, LA
I took my truck in for some body work to repair some rust spots on the pillar behind the doors. The mechanic also removed the truck bed so he could repair some body rust on the back of the cab. We also filled in some screw holes and 1 bullet hole in the back of the cab. There were also cracks in the rear wheel wells welded as well as separation between the inner and outer metal of the wheel well. There was some nasty rust pitting right next to the window on the driver's door that was fixed. Also rust pitting on the front of the hood we took care of. Here are some pictures of the work in progress.
He also power washed the frame in the back of the truck while we had the truck bed off. He then applied Chassis Saver Paint to the frame to protect it.
