goldneagle
- 1,007
- Slidell, LA
I finished painting the truck today. I started by unbolting the tool box mounted behind the cab. I then wiped down the surface with surface prep and primed some exposed spots. I got the top painted and then painted around the back window. I also finished painting the passenger side door and rocker panel. Once the paint was dry I used a razor blade to scrape the paint off the rear window as well as the triangle glass on the passenger side. I did not do the windshield yet. will let the paint dry till tomorrow and then scrape it off. I also need to paint the other 2 rims green. I saw some missed spots and will touch them up tomorrow. Here are pictures of the progress.
