Drock
- 12
- 0
- Eatonton GA
Banks sidewinder fuel line rerouting
Okay so I finally got a chance to start the install of my new sidewinder turbo. Wow this thing is fighting me every step of the way!. The exhaust manifold was the easy part! Soaked it in Kroil over night and it came right of. The block oil plug on the drivers side, of coarse had to have a nut welded on it to get it off, well 6 to be exact , but who's counting. Then the allen head of the pin inside the injection pump broke. Yes broke! So I had to get it out with a vise grips. Then weld a 6mm allen wrench into it , cut it off so I could put a normal wrench on it to reinstall it . Now I'm ready to install the new manifold but the factory fuel hard line is right smack in front of the flange for the crossover pipe. So now I need to reroute the fuel line but I don't know how or where I should go about this. The instructions don't mention anything about having to move the lines , much less how to do it? Do any of you have a pic of what you did? Or can you explain how you did it?
