rustystud
- 2,801
- Woodinville, Washington
This is so funny as my son is sitting in the front room watching this silly movie right now !View attachment 553077 I could not resist.
...you can also see the nail I trashed slamming it in the door. I smash my fingers every so often working, but MAN, that one hurt! Busted it right across the root. Not nearly as bad as poor 'sinker is prolly hurtin', though, sorry buddy!
My father was a carpenter and I would help him out at times. Once I hit my thumb with a 22oz framing hammer
Maybe I missed it in the TM, is there supposed to be oil on the felt washers?Felt on the adjusters is all I've come across, could you post a pic of the other ones?
This is the old style of keeping the brake shoes free at the anchor pin. The felts would come saturated with grease and this would keep the other parts from freezing up with rust. In todays modern world we use "Anti-Seize". I still would use the felts if you can get them. I would use a silicone based lubricant with PTFE like "Tri-Flow" on the felts.Maybe I missed it in the TM, is there supposed to be oil on the felt washers?
Hats off to you, I hope to never do this again, or at least not for a long time.As stated, I soak mine in grease, works good for me. I service my brakes and bearings after I go mudding every time, so I'm in there a lot.
Well, since I probably need to pull the front diff anyway, I guess I might as well plan on pulling the pan.I missed the oil pressure thing, that strikes me as not good.
