Pump and Hose REEL for the FSM....
We are making pretty good progress on the FEMTT's 'FSM' and are just about down to some wiring and plumbing.
The 1" 'Booster Hose' power reel is painted and installed and the manifold that connects the front and rear 600 gallon compartment is in place.
All we are lacking to bolt the diesel powered fire pump in place, are some modification to the pipe threads for the in- and outlets. My new 'helper' Branko modified the muffler to have the exit point up, so it can be routed through the top of the pump compartment. I hope this will reduce the amount of diesel smoke that the pump operator has to inhale.
I was going to use an Optima battery to run the starter on the pump and to power the Hannay hose reel, but as it turns out the reel is 24V!
A fact the seller on Ebay conveniently forgot to mention....lol.
Of course if I would have tried to find a 24V one, it would have been totally impossible to find anywhere!
So I guess I'm going to have to either run a 24V 6 gauge wire back there just for the reel, or use a series-parallel switch and utilize the 12V from the truck and the starter/booster battery from the fire pump to make the 24V needed.
Anyway, here are a few pics from yesterday and today:
Some are of a water transfer from the 5000 gallon tank behind the M920A1 in to the FEMTT's FSM. It is filled with 1200 gallons of H2O now, so it is time to try the crane on it tomorrow.....will report on the findings. If it can't lift it safely I will do something like what 'Andrmorr' has suggested in post #1077!
The others are of the MX7000 light bar installation and the progress in the pump compartment of the FEMTT's FSM....The open spot in the right top area of the compartment is where the fire pump is going to reside.....
My friend stopped by and stated that he never though he would ever see me paint anything RED!!!!! lol
Soni
